05-25-2019, 10:17 AM | #1 |
Active Member
Wanted to Buy 66 K20 Original Rear Spring Blocks
Hi there! New to the site, working on a 66 K20 that was trash and slowly bringing her back. I want to put the original rear spring blocks in - My truck had PO blocks that were, well, lets be kind and say "not original". I am in CT. Anyone have a pair to sell?
05-25-2019, 11:12 AM | #2 |
Re: Wanted to Buy 66 K20 Original Rear Spring Blocks
Hi Joe. I believe I still have a clean set from a 1966 GMC K20. I will post pics later today. Thanks, Harlow
05-25-2019, 11:35 AM | #3 |
Active Member
05-25-2019, 01:21 PM | #4 |
Hi Joe. Sorry, it looks like I only have the front blocks left. I am working on getting another 64-66 vintage K20. I will let you know if I get it and if the rear blocks are intact. Thanks, Harlow
05-25-2019, 02:37 PM | #5 |
Active Member
Thanks for looking, Harlow. I have the front blocks in good shape, just need the rears. Appreciate your courtesy!
06-10-2019, 03:45 PM | #7 |
Active Member
06-10-2019, 06:40 PM | #9 |
Active Member
I'm not sure if they did - My truck does not have lift blocks up front, but does have a couple of blocks on top of the springs, more like "Bump Stops"
06-10-2019, 06:42 PM | #10 |
Active Member
I am looking for original rear blocks. This is what I have today...
06-10-2019, 08:03 PM | #12 |
Active Member
06-27-2019, 11:48 PM | #13 |
Active Member
Still looking...
07-02-2019, 10:04 AM | #14 |
07-02-2019, 10:50 AM | #15 |
Active Member
Thank you yes. It may be correct. This is the block that goes between the bottom of the spring and the axle perch. The photos that I have seen show what looks to be similar to an I think it incorporates a bump stop too. Thank you!
07-02-2019, 08:23 PM | #16 |
Active Member
Here are a few photos of what I think are original blocks
07-03-2019, 12:12 AM | #17 |
Up for grabs:
07-03-2019, 06:50 AM | #18 |
Active Member
That’s it! How do I make them mine?
07-03-2019, 09:14 AM | #19 |
Well lets see, my Garage needs a new roof....my tires are bald....!
PM me with your contact info and i ship them out! Cheers Eddy |
07-04-2019, 09:25 AM | #20 |
Active Member
07-05-2019, 12:32 AM | #21 |
Wow When I got My 1 st 4x4 66 GMC I Use to Think What Were Thet Thinking With Those Strange Blocks
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
07-05-2019, 07:07 AM | #22 |
Active Member
Yes, they are strange for sure. I guess that a plain rectangular block is substantially heavier. Perhaps the designers wanted to reduce the weight a little. Anyway I prefer the original ones because they are "original".
07-05-2019, 07:35 AM | #23 |
Check The Champ, Demonstrator
I have a pair without the shock mount on them.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-05-2019, 11:22 AM | #24 |
Active Member
Thanks but i think dSuper5 has a pair for me, just waiting to hear. Looking at photos, I don't think these blocks have a shock mount, but do have a bump stop. It appears that 3/4 ton trucks have the lower shock mount welded to the axle housing. It appears the one ton trucks had no rear shocks at all. I am not sure on this but both of my Eaton one ton H072 axles don't have the shock tabs - One is a 65 and the other is a 66...
Tags |
66k20 |
