Son's 68 c10 Short Bed
Okay, so here's the backstory. I bought this 1968 c10 short bed about 7 years ago. The truck had been frame off restored in 2005 and daily driven for a while. It was then sold and left to sit outside for a couple of years and then sold to me. I am the 4th owner of the truck and it appears to have spent all of its life in New Mexico. When I bought it, I lowered it, put wheels and tires on it, swapped the original 327 for a 330 hp GMPP crate 350. I also added fuel injection and redid the interior. I drove the truck for a few years with the plan all along of it becoming my son's truck when he was old enough. I told him I would get the truck mechanically sound and a good driver but he would be responsible for working on it and getting it ready for paint. Fortunately, my dad owns a hot rod shop (Wild West Street Rods) and he does exceptional paint and body work. Well, my son turned 15 yesterday. He and I spent a day this past weekend pulling everything off of it we could in anticipation of it heading down to the shop.
The plan is to do paint and body work and get it back together. I am hoping to start putting it back together by the end of the summer. This is a low dollar build. I am wanting him to have a nice, driver-quality truck that he put a little sweat equity into. Today is day 1, and they have the bed off of it.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 Last edited by Camaroguy; 06-03-2019 at 11:11 AM. |
Re: Son's 68 c10 Short Bed
One of the bigger challenges with this truck is going to be how to sort out the inside of the bed. There is a big plate welded on the front of the floor in place of the original floor. Also, the front panel had a plate of metal welded to it. I assume both were done to cover damage or rust. The entire inside of the bed was also covered in bed liner.
So half of yesterday was spent trying to heat up and scrape off the bed liner with little success. Going to have to come up with another plan. I ordered a new panel for the front of the bed and will probably order a front section of the floor and new tubs as well.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
He is almost finished cutting out the flat panel that was added to the front of the bed floor.
He got the front of the bed floor cut out.
![]() Join Date: Jan 2007
Nice truck. What color is he going with?
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Thanks! I am pretty sure he's going to do it in Toyota Calvary Blue. It's a solid light blue that leans gray. He doesn't want two-tone so it will be solid with most of the trim on it.
This truck had a little rust in the bottom of both doors. I was able to spend part of the day on it yesterday and got the passenger side door fixed.
One more picture of him pulling it in. This is exciting for me. Seeing my boy growing up and expressing an interest in this. I ordered the front section of the bed floor yesterday as well.
![]() Join Date: Feb 2015
That really is fantastic! I hope my kids get the bug at some point!
'67 C10 shortie. |
I like the color. Is it a non metallic, base, clear? Is it water based?....I noticed it is late model. Thanks.
Thanks, I like it too. It's a non metallic. I'm not sure what the actual Toyota color is, but if it's water base, I will have the paint store mix something to mirror it. We normally do base/clear but have recently done some higher end stuff in single stage and have been really happy with the results. Might consider that with this one.
#12 | |
The first two pics are of the Lincoln the third is of one of my dads.
Both doors are in the first coat of primer.
![]() Join Date: Nov 2010
Awesome!!!
Something that he (and you) will remember for a lifetime. Love the house pic! |
#15 | |
#16 |
I was able to spend a couple of hours at the shop today and got the rust cut out and patched on the driver's door. This one was worse than the passenger side. I still need to clean up the welds but it's all good now.
This truck is actually pretty solid. I'm really impressed at how good all the sheet metal fits.
#17 |
Yesterday, he got the passenger door completely stripped both inside and out. Only two spots on the door needed any filler, and the front spot is from the rust repair. It's crazy how good this door is. I hope the rest of the truck is half as nice.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 Last edited by Camaroguy; 06-04-2019 at 12:19 PM. |
#18 |
Looks great! What are you using to strip the paint?
#19 |
Thank you. For the most part, he's using a die grinder with a sanding disc.
#20 |
Cab and front clip are all stripped. Rust repaired in cab corners. Starting bodywork tomorrow.
#21 |
you guys are on a roll
#22 |
Couple of other small updates. Yesterday, he got the cowl stripped. I guess there were two small rust spots in the bottom of the cowl and he will have those repaired today. Also, after getting the drip rail stripped they brushed in some DP primer in preparation for seam sealing.
#23 |
I got a chance to stop by this afternoon and they have started on the body work. We should have it in primer by Friday.
#24 |
And we have primer.
#25 |
![]() Join Date: Aug 2018
I wish I had all summer to work on my truck! But then my money wouldn't keep up...
What a great project for you and your son for the summer.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
