Old 05-30-2019, 09:28 PM   #1
uncle
Drug a 4 Eye Home.
Not a lot of rust but plenty of dents. 327/glide with ps,pb and a/c.
uncle is offline   Reply With Quote
Old 05-30-2019, 09:29 PM   #2
uncle
Re: Drug a 4 Eye Home.
2222
Old 05-30-2019, 09:32 PM   #3
uncle
3333
Old 05-30-2019, 09:33 PM   #4
uncle
4444
Old 05-30-2019, 09:42 PM   #5
68Gold/white
Since I'm not a GMC nerd (Have only had Chevrolets) what year??? I know it's not a 67...
Very nice!!!
68Gold/white is offline   Reply With Quote
Old 05-30-2019, 09:49 PM   #6
BROWN 70
BROWN 70's Avatar
hi, dig the gmc. welcome to the 4 eye club. 1968? with air. how cool BROWN 70
BROWN 70 is offline   Reply With Quote
Old 05-30-2019, 10:16 PM   #7
weq92f
weq92f's Avatar
Nice truck!
Flip fa ya...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-31-2019, 12:02 AM   #8
Old_Gold
Old_Gold's Avatar
Love it, and great to see another 4 eye!
Plans for it??
Old_Gold is offline   Reply With Quote
Old 05-31-2019, 06:05 AM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks pretty good in the pics. Congrats!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-31-2019, 06:31 AM   #10
Yep, '68. Same trim, hood, and mirrors as 67/68 Chevy. That has my all time favorite best engine in there, if it's original and my seat of the pants says it is.
Old 05-31-2019, 09:42 AM   #11
uncle
It runs but needs brake work. Gonna do brakes,seat,a/c and try to fix some of the dents.
Old 05-31-2019, 10:01 AM   #12
68Gold/white
LOL, every pre-71 chevy pickup needs brake work, specifically DISC brake work...
I like it!!!
I have read here that AC on a 67 or 68 is highly uncommon!
When you do get the AC going, I'd like to know what you had to go through to make it function.
You plan to take the seat to an upholstery shop???
What does the SPID look like???
Old 05-31-2019, 10:49 AM   #13
nikwho
nikwho's Avatar
Congrats! I think that the '68 GMC's have the best look, of all of the 67-72's! Good score! I was hoping my '68 GMC had its original 327 when I bought it. It turned out to be a 305, so I did the only reasonable thing; swapped a 427 big block into it! Sweet find. Have you decoded the engine numbers yet?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 05-31-2019, 09:14 PM   #14
uncle
Thanks for the flip. Not sure what I’m going to do with the seat since I don’t think you can get an original cover. Seat needs a lot of work. As far as the air conditioning goes it still has the belt on it so I’m just gonna try to put a little r12 to see what it does. The truck has been sitting in a barn for 25 years. As far as I know it is the original 327 that has supposedly been rebuilt about 25 years ago. It does run so that’s a plus. If it’s like anything else it will be a slow process for me.
Old 05-31-2019, 11:33 PM   #15
67_C-30
I have a radical idea!
67_C-30's Avatar
Nice score! It kinda reminds of that one you sold Red!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-01-2019, 10:06 AM   #16
kidatheart
kidatheart's Avatar
That's one of the best colors, in my opinion.
kidatheart is offline   Reply With Quote
Old 06-01-2019, 10:19 AM   #17
54blackhornet
54blackhornet's Avatar
I don’t understand why the GMC gets so little love ? They where more expensive, fewer built and now much rarer then the C10. All those statistics should make them more desirable but they seem to be not...?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-01-2019, 10:44 AM   #18
shoveldug
Nice!
paypal is dwl65101@yahoo.com
shoveldug is offline   Reply With Quote
Old 06-01-2019, 11:06 PM   #19
kingsolver72
10/30/19
kingsolver72's Avatar
I think part of the answer to your rhetorical question you answered with “more expensive, fewer built and now much rarer than the C10” I’ve never owned a 67-72 GMC mostly because I haven’t had the opportunity to purchase one.
Perhaps if the car shows did GMC restorations they’d be more “desirable” to the folks that want in on the latest trend.
If you own one count your blessings.
I get your premise for sure.
kingsolver72 is offline   Reply With Quote
Old 06-01-2019, 01:30 PM   #20
kazoocruiser
1:24 PM 5/15/2019
[QUOTE=uncle;8534863]As far as the air conditioning goes it still has the belt on it so I’m just gonna try to put a little r12 to see what it does. /QUOTE]
Before you do that, in case you have a leak, this step might save you some time, expense and lost refrigerant.
First, take a test light and see if you have power through the low pressure switch. It is located on the accumulator / dryer. If you don't have power through the switch, the compressor will not cycle. If the light does not come on at all, checking the fuses and related wiring will need to be done. The low pressure switch is designed to prevent compressor cycling and damage if refrigerant gets low from a leak.
If your AC system got low, it would have allowed normal air into the lines, accumulator, condenser, evaporator, and compressor. With the entrance of the humidity with the air, the moisture combines with the R-12 and creates corrosive compounds, which will make short work of the aluminum parts internally. I did a search for "what happens chemically if R-12 combines with water".
If you depress one of the Shrader valves, with the engine off, it will give you an idea if there is any refrigerant in the unit at all. You could do this with gauges to see what is actually in the system. AC gauges are available as part of Loan-a-tool programs at auto-parts stores.
Reach inside while the engine is off, and see if the clutch (inside part) to the compressor will rotate freely. If it's locked, it is counterproductive to add refrigerant at this point. I still have a belt on my 1981, with a locked compressor, but the next project is pulling a vacuum after I replace the compressor that is definitely bad on my truck.
If you have to invest in the parts to repair your truck, and you do have some residual R-12 in the system, there is no telling if someone added a wacky-charge of something other than R-12. Atmospherically venting a chemical that has been discovered to be as dangerous to the environment as R-12 is really not a good idea. There are "pop-bags" that can be hooked into the Shrader valve that will capture whatever needs to be removed safely.
Letting people vent on the imaginary Internet is safer than venting R-12 in the world we live in. Future grandchildren will appreciate one less R-12 fart bubble.
If you do have to replace parts, 134a conversion is a lot less expensive if other parts fail and cause loss of refrigerant after repair work was done to replace one failed componant.
Hope this helps.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C.
Some of the Build progress:
https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA
1981 Harley Davidson.
Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it.
kazoocruiser is offline   Reply With Quote
Old 06-01-2019, 01:44 PM   #21
68Gold/white
[quote=kazoocruiser;8535135]1:24 PM 5/15/2019
Hope this helps.
Good info, Kazoo!!!
I work on AC stuff on school buses, am not an expert but have learned a lot...
When you buy a new compressor, the manufacturer recommends to stand the compressor on it's end...for some amount of time. I'm sure so that the seal has oil on it when first cycled???
I wonder if the same would apply to a compressor like this??? Sitting for too long, with no oil on the seal.
Then I wonder if sitting too long causes the deal to dry out, would that contribute to the loss of refrigerant???
Can R134 be used in a system with the old style POA valve still on it??? Reason I asked, I've seen new POA valves advertised for sale for both R12, and R134???
Old 06-02-2019, 05:02 PM   #22
uncle
Thanks for the a/c advice. I guess I should’ve been a little more detailed than just saying I’m going to add some R12 but again I appreciate all the advice. Also can anyone tell me what this color interior is called on a 68? No spid. I think I have what is a correct seat material for a GMC custom in the following pictures.
