06-04-2019, 12:34 AM | #1 |
Cleaning Engine Block?
I Stripped Down My Engine Block To Bare Metal and Wont Have My Paint Till Next Week.
Just Wondering How I Should Clean and Store The Block Till i Apply The Epoxy Primer? Thanks Posted via Mobile Device |
06-04-2019, 08:22 AM | #2 |
Re: Cleaning Engine Block?
clean it with a wire brush and some degreaser, (expect for the cylinders) and then after you give it a good douch/wipe down with solvent spray it down real good with WD 40 to prevent flash rust.
I prefer to use Isopropyl alcohol (90 percent) for my garage solvents, it is cheap and evaporates clean.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
06-04-2019, 09:43 AM | #3 |
06-04-2019, 11:48 AM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Use a Por-15 equivalent and flash rust is no longer an issue...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
