4 speed granny gear to 4 speed Muncie
Hey all,
I’ve got a 69 c10 swb fleetside with a 4 speed granny gear, I also have a Muncie m21 that is like to put in the truck and I’m wondering if anyone has done this swap and what it involves? As far as I know I just need to shorten the driveshaft? Thanks in advance Tyler Posted via Mobile Device |
Re: 4 speed granny gear to 4 speed Muncie
A few issues to take into account :
The input retainers will likely be different dimensions, This is the large round hole in the bell housing that centers the transmission. The aftermarket makes a sleeve that will convert the car Muncie four-speed to the larger truck bell housing hole. Some of the car 4 speed Muncies Will have the Speedometer output on the passenger side which would need a longer cable to reach. Car transmissions will not have the two lower holes that mount to the bell housing threaded as on the truck transmission. You’ll have to use a nut and bolt arrangement instead. You will have to fab up A reverse light switch arrangement. Probably have to make a drive shaft from scratch. Your original driveshaft will have a slip yoke in the shaft itself that won’t work on the car transmission. The shifter can be a little tricky, but there are several solutions to clear the bench seat. I did the swap myself about 30 years ago and I used a 55-57 Chevrolet car Hurst shifter and it worked out well. That said depending on the transmission there are different mounting arrangements so not all shifters fit the same . Other than that it’s pretty much a bolt in. One more thing to consider: if the trans you have is a real M21 ( very unlikely as these are very rare ) this will have a 2.20 first gear which would positively suck to drive in that truck, not a deep enough first gear. More likely you have the more common M 20 Which has a more livable 2.52 first gear. Steve weim55 Colorado |
#3 | |
The yoke will Be different for the granny 4 speed but the remaining driveshaft could indeed be the original and if that’s the case would work without modification with the proper yoke.
![]() Join Date: Dec 2013
Here's a good video to watch before you buy a rebuilt Muncie M22 off ebay / Craigslist .
![]() https://www.youtube.com/watch?v=RyOWKW21I0c
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#6 | |
Does anyone happen to know the length of a stock 3speed driveshaft?
