Old 06-17-2019, 11:21 AM   #1
CustomCab66
CustomCab66's Avatar
Smile Dads 1966 C-10
So after I did an LS swap on my 66 SWB custom cab my dad decided to put his 1966 back together his truck is a standard cab long bed fleet side. Originally it was a 327V8 with a three on the tree. Since then It was switched to a 4 on the floor and the old 327 replaced with a used 350. It was his daily driver back when I was a little tike. He decided to tear it apart maybe 10 years ago and the plan was to give it a freshening up and give it to my little brother. My little brother moved out of the state so it just sat in the corner of the shop collecting dust. I’ll start adding pictures of the truck and the progress. It has come a long way since last summer. Pictures to follow
CustomCab66 is offline   Reply With Quote
Old 06-17-2019, 11:37 AM   #2
CustomCab66
Re: Dads 1966 C-10
So I started receiving pictures from my little dad and I was super stoked that he was working on the yellow truck. Up until this point the cab was sitting in the corner of the shop. It needed floor patches cab corners and the rocker panels replaced. Here’s my dad 65 years young
Old 06-17-2019, 12:12 PM   #3
CustomCab66
Re: Dads 1966 C-10
Passenger side floor and rocker panel work. The floor support was salvageable also the cab corner was replaced. Follow along for the build
Old 06-17-2019, 12:17 PM   #4
CustomCab66
Re: Dads 1966 C-10
Everything is looking way better welds smoothed out and cab corner in primer.
Old 06-17-2019, 01:40 PM   #5
CustomCab66
Re: Dads 1966 C-10
Wiper motor mount was rusted out pretty bad. Salvaged one from a doner truck. Cut removed and replaced
Old 06-17-2019, 01:54 PM   #6
CustomCab66
Re: Dads 1966 C-10
September 3rd 2018:
Used an NOS GM rocker panel on this side. Floor is looking good. The underside was cleaned and coated with undercoating
Old 06-18-2019, 10:00 AM   #7
Ronzo
Ronzo's Avatar
Re: Dads 1966 C-10
Great build, following along...
Ronzo is offline   Reply With Quote
Old 06-18-2019, 12:19 PM   #8
CustomCab66
Re: Dads 1966 C-10
Wiring harness for the PCM is longer than I like and so it makes it difficult to hide the wires under the dash. I will be shortening each wire one by one. I started on it last Friday but I had to head home because of work. Hopefully I can make it back out there a couple more times this summer and finish up the computer wiring.
Old 06-18-2019, 10:52 PM   #9
TxCajun
TxCajun's Avatar
Re: Dads 1966 C-10
Wow! That's a lot of progress. Looks great!
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 06-19-2019, 12:18 AM   #10
Lokin4AReason
Lokin4AReason's Avatar
Re: Dads 1966 C-10
Looking good. Keep the progress coming . . . .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 06-22-2019, 04:26 PM   #11
CustomCab66
Re: Dads 1966 C-10
Tailgate was just painted factory dark yellow with ivory letters. Those letters are not decals they were painted first then they were taped off. Once the body color was sprayed the whole tailgate was cleared
Old 06-22-2019, 08:27 PM   #12
CustomCab66
Re: Dads 1966 C-10
Header panel is done and in clear, fender emblem detailed and installed so the fenders are ready to mount.
Old 06-22-2019, 11:27 PM   #13
Captainfab
60-66 Nut
Re: Dads 1966 C-10
Good job on the masking and painting.....Looking really nice
Old 06-26-2019, 09:08 PM   #14
CustomCab66
Re: Dads 1966 C-10
Header panel and grille together. My dad picked up this set of Cragar S/S wheels and nearly brand new set of Michelin tires for 500. What a score
Old 06-27-2019, 05:50 AM   #15
Android04
Android04's Avatar
Re: Dads 1966 C-10
Looks extremely clean.
Android04 is offline   Reply With Quote
Old 07-01-2019, 12:01 AM   #16
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: Dads 1966 C-10
Really Great Looking Truck
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 07-04-2019, 12:55 AM   #17
CustomCab66
Re: Dads 1966 C-10
Went to dads on Sunday and continued where I left off. LS harness is now completed and it’s now standalone. I converted the main cab harness to accept the gauge cluster since the truck originally had warning lights and the harness is now installed. My dad picked up a fuel pump because the late 80’s pump I. The donor fuel tanks was for throttle body injection. I turned the key and the 5.3 busted right off. Wheels installed
Old 07-22-2019, 03:08 PM   #18
CustomCab66
Re: Dads 1966 C-10
Inner fenders and core support on, and the radiator is in place so the shroud can sorted out
Old 07-22-2019, 03:12 PM   #19
CustomCab66
Re: Dads 1966 C-10
Hole cut in the shroud for the electric fan. I wired the two speed fan to the pcm so the fan will switch on and off as needed. Transmission cooler has been mounted
Old 10-06-2019, 09:12 AM   #20
joesscamaro
Re: Dads 1966 C-10
Nice job guys...truck is looking good!
joesscamaro is offline   Reply With Quote
Old 10-09-2019, 09:50 AM   #21
88Stanger
88Stanger's Avatar
Re: Dads 1966 C-10
Damn fine job!! I like the build, great color combo too.
88Stanger is offline   Reply With Quote
Old 10-09-2019, 01:06 PM   #22
66c10Steve
66c10Steve's Avatar
Re: Dads 1966 C-10
Wow, awesome job....it's looking great
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694
Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/
66c10Steve is offline   Reply With Quote
Old 10-11-2019, 03:49 PM   #23
66ChevyMax
66ChevyMax's Avatar
Re: Dads 1966 C-10
Looking Great!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 06-16-2020, 10:35 PM   #24
CustomCab66
Re: Dads 1966 C-10
Went up and helped my dad fix the gas gauge so we could put the bed on. He had already relocated the gas tank under the bed of the truck so the gauge needed to be fixed first. So other than a radio the truck is ready. My dad decided he wants to go with steel wheels painted yellow with factory white hubcaps. It will look bone stock And will be such a sleeper
Old 06-17-2020, 09:18 AM   #25
bsarts
bsarts's Avatar
Re: Dads 1966 C-10
The truck looks fantastic! Your Dad did a first rate job on her!
bsarts is offline   Reply With Quote
