![]() Join Date: Jan 2018
Lowering Regrets
I recently put a 2.5" drop spindle, 2" springs, lowered shocks on the front along with 40 series tires on 20's. I replaced all wear items (steering and suspension) and got a quite pricey dynamic alignment. I did a 5" springs, shock relocators, new shocks, and adjustable track bar with 50 series tires on 20's in the rear. It looks really good; it is made to be a daily driver though and it rides horribly. I can feel every crack in the road, it clangs, it bangs, (both front and rear), I can't get in and out of driveways, I have maybe an inch max before I am into the bumps front and rear, I am tucking tires all around. This is all my opinion on my vehicle but I hate it and wish I had not lowered it and stuck with my 15" rallys. Now I am trying to figure out how to get it back to as stock as possible without changing the spindles and having to pull the spring relocators/adjustable track bar (because I don't have them for various reasons). Thinking 16" rallys, stock front springs on the 2.5" drop spindles, 3" rear drop springs, and new front shocks may get me closer for the least amount of money. This was all my own doing but wanted to post a differing opinion for folks that may be on the fence about lowering their trucks.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Re: Lowering Regrets
sorry to hear that..
some of us know we love lowered trucks some of us know we hate lowered trucks some of us are in the middle and sometimes learn the hard way only suggestion I have to consider.. if it's not an heirloom or otherwise sentimental truck, consider selling and buying another stock one? with all the money and time wrapped up in this one, maybe cut your losses and move into another truck.. of course I don't know the model, options, or any other details about it.. but that's what I would do if I made a mistake on something I bought.. good luck!
I started out with nothing - and I still have most of it |
![]() Join Date: Jun 2009
I think you are on the right track if you want a change. Put the stock front springs back on. A little less drop in the rear. And more tire sidewall should all help. See how that goes. You may be getting into the bumpstops where you are at now. Maybe get shorter ones and see what happens.
#4 | |
1. 2.5" spindles, stock springs, 3" rear springs, 20's with 50's on front (I think this may look bad to me due to wheel gap/fat front tires) 2. 2.5" spindles, stock springs, 3" rear springs, 16" rallyes (16" rallyes are expensive) 3. 2" springs, stock spindles, 3" rear springs, 15" rallyes (will still be on bumps in front) 4. all stock with 15" rallyes (I would need to rebuy everything, ouch) Selling my truck over my suspension screw up isn't feasible as I am $25K into this (SWB conversion/LS swap/new everything).
#5 | |
good luck straightening it all out!
#6 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
You mention nothing about making room for suspension travel. You have limited the room between moving parts, so you have to open up some room so parts don't bottom out. (your words,... "rides horribly) Up front you remove the rubber bump stops and the stands they mount on. I leave part of the steering top for the spindle to contact. The rear you also need to remove the rubber bump stop and add a c-notch if you want even more travel. I would start with just removing the bump stop and adding a shorter version like Energy Suspension sells. If you don't have a front sway bar,... you need one. This will help with body roll. Take some pics of your current set up (the suspension) not the truck. My 2wd blazer bottomed out a lot until I added a rear c-notch. It's like driving a different blazer. Its bagged now, so that's a whole different conversation.
I have the 4/6 drop on mine, very happy with the set up. 20's with 245/45 front and 295/40 on rear,front sway bar and C notch. I think it rides pretty good, not to rough and not alot of roll when hitting a corner. My idea of smooth and yours are different but I'm happy. Good luck
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Start cheap and work your way up. You can find stock front springs easy and cheap. You can remove bump stops easy. You can find used rear springs pretty cheap and easy. If that doesn’t work start on tires wheels etc.
I leave part of the steering top for the spindle to contact. Can you elaborate further on this (the second part)? My clanging in the front is coming from my spring compressing too much and the coils banging against each other...you can hear the sort of recoil/reverberating sound of the coil clanging almost like when I hit a bump the control arms are separating leaving the spring "hanging in mid air" and then slamming back down on it sort of clang. The bang is from the back where I suspect I am smashing the bumps/hitting the frame. I do have a front sway bar. Bigger front tires may be the way to go as well, the 50's look huge on the back so perhaps 45 is a better option although my tires are pretty tucked already in the front. Is it feasible to trim the rear mounts down a bit? I need to weigh it though whether I want to go further down the lowered path or bite the bullet and sell everything/return to stock. I drive 25K+ miles a year and the feasibility of DDing this truck is not good as I feel I need to really baby it.
#10 | |
Here’s a picture of the lower a-arms I modify.
never mind
Pics would help a lot
like everyone else is saying... pull the bump stops out before doing anything else. It cost nothing and gives you another 1.5" travel.
i have a 4/6 drop and find it great to drive. (although my daily is an accord so im used to tighter suspension/handling) |
#14 | |
Another option is a 17” rim and tire combo, you will have lots of tire options (bigger sidwalls), plus, the cost would be offset when you sell the 20’s. American racing makes a 17 inch rally wheel that looks great.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. Last edited by cornerstone; 06-18-2019 at 05:22 PM. Reason: More info. |
#15 |
Not really close ups of the suspension compressed or anything but what I am working with.
#16 |
Also what brand of lowering components did you use.
Your truck doesn’t look that low,...
#17 | |
CPP 2" Springs McCaughy 2.5" Spindles Belltech shocks (these fit like crap btw they are too fat so they have to be spaced out significantly from the frame) Rear: CPP 5" springs CPP adjustable trac bar CPP shock relocators KYP Gas a just shocks
#18 |
I highlighted your issues in red. I've never been happy with Chinese Produced Products.
#19 |
I think you are on point, I walk out in the morning and it just keeps settling further and further. I have coils in the rear completely collapsed and laying on the trailing arm.
#20 |
Yep those springs are crap... on the bright side new set of quality springs aren’t that much money and they may give you the ride and height you’re looking for. The expensive alignment is a bummer though.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#21 | |
I had the 4.5/6.75 drop on my truck before with ECE parts on 17" tires. I never had any real complaints with ride or handling. Due to the nature of driving a lowered truck, there were certain speed bumps and driveways I had to be careful on, but no more than with a car of any sort. ![]()
#22 |
![]() Join Date: Sep 2014
[QUOTE=lolife99;8544648]Also what brand of lowering components did you use.
Your truck doesn’t look that low,...[/QUOT My ECE (Early Classic) stock front springs w/2.5" drop spindles and their 4" drop springs in the back = no rubbing/banging and rides great. I am running original replacement stops front and back too. |
#23 |
I have a radical idea!
I hated my first lowered truck until I removed the bump stops as well.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#24 |
I put 3" springs in front and 3" springs in rear with 1" block. I cut both stops in half and have had a pretty decent ride. The 70 series 15" tires really help with the ride as well.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#25 |
![]() Join Date: Feb 2016
If there is play in the lower control arm bushings you can get loud clangs and bangs from the front end. Lift the front end and compress the front springs enough (use a coil spring compressor)so the preload from the spring is removed from the lower control arm. Then try to move the arm around with a large dead blow hammer. You should not be able to see the arm move around when you hit it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
