06-22-2019, 04:18 PM | #1 |
Brake line coil off master cylinder necessary?
I am redoing all my brake lines in conjunction with adding a Wilwood master and proportioning valve. Question is whether or not the coils are necessary or not that are generally right off the master.
I know GM did it on most stock trucks, but I see a lot of trucks without them. I want to do some different routing to clean things up a bit while I’m at it, and don’t really want to do the coils. If they are necessary, I assume thy should be horizontal instead of vertical so air can’t get trapped in the top part of the coil. |
06-22-2019, 04:22 PM | #2 |
Re: Brake line coil off master cylinder necessary?
The coils allow for flex between the body and frame...I used -3an ss hoses on mine to eliminate the coils..
06-22-2019, 09:10 PM | #3 |
Thanks for the reply. I think I am going to stay with the double flare 3/16 line. Broke the freakin’ double flare die today, so I am on hold anyway. I see so many clean lines run, like TheSub, OMGosh, that engine bay is insanely clean. Mine is nowhere near that, nor will it ever be, but I try to clean things up as I go.
06-22-2019, 09:16 PM | #4 |
those fittings I used are double flare to -an....nothing wrong with using the coils though
06-22-2019, 10:13 PM | #5 |
I don't know how the trucks were assembled but for Camaros the master cylinder was attached to the brake lines and left unsupported when the subframe was assembled. Only the two brakes lines held it up. The coils allowed for movement of the master cylinder without damaging them. When the subframe was attached to the body it was then bolted to the firewall or booster.
So, to answer your question, I would say it's not absolutely necessary to include the coils. There is negligible movement between the body and frame. I believe a little bit of slack in the lines wouldn't hurt however, mostly to make it easier to connect or disconnect the lines at the master cylinder. |
06-23-2019, 08:11 AM | #6 |
Trucks used a temporary master cylinder "slave" bracket on the chassis line to support the assembled system until it was attached to the front of dash. The slave bracket was then removed and recycled back to the installation point to be reused.
The brake system is completely evacuated, filled and function tested by this point. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-24-2019 at 02:50 PM. |
06-23-2019, 06:11 AM | #7 |
Moderator
Not needed.
06-23-2019, 08:19 AM | #8 |
06-23-2019, 10:44 AM | #9 | |
Moderator
I was thinking about going all chrome instead of all Yellow zinc in the engine compartment...
09-23-2019, 04:05 PM | #10 | |
I didn't realize that the reason I didn't have good power assist was not because of the size of the booster, it was the fact that the vacuum port I used on the 1" carb adapter was a blind hole. It was never drilled to expose it to manifold vacuum! I didn't have poor power brakes; I didn't have any at all! I have since then attached the booster to the carb port. |
06-23-2019, 11:49 AM | #11 |
I have been running like this for 2 years now. I used a coupler so I could use my original brake rod with the later model power booster. There is a locking nut on there, you just can't see it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-24-2019, 11:14 AM | #12 |
Its a non issue, makes for easier mast cylinder replacement though...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-25-2019, 01:08 PM | #13 |
No coils and no issues so far.
06-27-2019, 01:47 AM | #14 |
06-27-2019, 10:08 AM | #15 |
I think its for a ‘71 non-power disc/drum c10. I used an early 80’s prop valve with warning light switch, mounted under the fan shroud like the square bodies.
06-29-2019, 12:21 PM | #16 |
I was curious about that master cylinder, too. Do you happen to know the exact brand/model? I like how it's more square and looks more like the old, pre-60s style/shape. Seems smaller than the later style too. It's a little less obviously out of place that most. Wondering where you found that one. Thx.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
06-29-2019, 12:25 PM | #17 | |
Moderator
06-27-2019, 02:42 AM | #18 |
As others have mentioned, the coils are there to take up motion between the body and frame. Yes, you can get by without, just pay attention to the motion. See how in The Rocknrod and dracko's pictures the lines go way over toward the driver's side and come back? It spreads the motion out over a whole bunch of line. That is more or less what the coils do.
Here's a disc brake conversion done in the 80s: Last edited by bloo; 06-27-2019 at 02:59 AM. |
06-29-2019, 12:27 PM | #19 |
That master is like this one at AutoZone
NM1494 https://www.autozone.com/brakes-and-...03_0_2558_2867 |
06-29-2019, 12:39 PM | #20 |
Moderator
If your dyslexic.
06-29-2019, 01:59 PM | #21 |
Yeah, the rear brake reservoir is in front.
It looks like the same casting as the one I posted. The fittings are appear to be a different size though. IIRC it was for a mid 70s Ford van or truck (1978 econoline?). Disc/drum, 1-1/8" bore. |
06-29-2019, 02:14 PM | #22 |
I got it from rock auto. Raybestos MC39177
06-30-2019, 11:43 AM | #23 |
cpp on mine.
06-30-2019, 12:57 PM | #24 |
Moderator
That's sweet right there.
06-30-2019, 02:18 PM | #25 |
I went as far to as to recreate the factory coils.
Lots of ways to go about this... |
