Old 06-23-2019, 11:53 AM   #1
vet57air
vet57air's Avatar
Tailgate bumper
Squared up my 66 SWB fleetside box and have the Mar-K tailgate fitting well (no chains). The tailgate sits on the box metal, no rubber bumpers? Metal on metal will make a mess of new paint in short order. No room to put a bumper as it would push the tailgate out. Is there a trick to fix this?
vet57air is offline   Reply With Quote
Old 06-23-2019, 07:26 PM   #2
vet57air
vet57air's Avatar
Re: Tailgate bumper
Thinking major surgery to box to allow for room for a rubber bumper? Stock it looks like tailgate rests on box, metal to metal?
Old 06-23-2019, 08:37 PM   #3
Clyde65
Clyde65's Avatar
Re: Tailgate bumper
Got a picture of what your asking??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-23-2019, 11:00 PM   #4
vet57air
vet57air's Avatar
Re: Tailgate bumper
When the tailgate closes, it stops when it hits the metal of the bed sides. Later trucks, 67-72 have a little more room and have a rubber bumper to save the paint. No room to do that on a 60-66. Must be a way?
Old 06-24-2019, 07:40 AM   #5
OldGyrene
OldGyrene's Avatar
Re: Tailgate bumper
Originally Posted by vet57air View Post
Attachment 1913900
I have always used a small piece of self adhesive weather strip.
Jake
Old fart in Western NE
OldGyrene is offline   Reply With Quote
Old 06-25-2019, 03:47 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
Re: Tailgate bumper
If you're not using the original tailgate chain and hook to secure the tailgate, what are you using to lock the tailgate in the up or down positions? I ask because I use a hidden latch system with pins that lock the tailgate in the up position with no contact with the bedsides and no movement.
Attachment 1913900
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-25-2019, 04:47 PM   #7
vet57air
vet57air's Avatar
Re: Tailgate bumper
I have good gaps with my Mar-K tailgate. I have plastic trunions so there is no side to side movement. It has the hidden bear claw type latches.
The issue is that 60-66 tailgates in the fully up position rest on the metal of the stake pockets. I don't want this as it will ware paint. 67-72 have a nice recessed rubber bumper to stop the tailgate in its full up position. I want the tailgate to fit flush but have enough room to fit a rubber bumper. Short of cutting and welding the stake pocket the height of the tailgate, I am not sure what to do. I am sure someone has run into this before?
Old 06-26-2019, 01:53 PM   #8
vin63
vin63's Avatar
Re: Tailgate bumper
My tailgate with the hidden pin latches do not contact the bedside stake pockets. The mount for the pin receiver from Mar-K is very accurate in spacing the tailgate so there is no metal-to-metal contact. In fact, there is enough room for my tailgate guard.
Old 06-24-2019, 11:58 AM   #9
Clyde65
Clyde65's Avatar
Re: Tailgate bumper
I honestly never even looked to see if there was some rubbing....now I’ll have to look when I get home. I know I didn’t put any weatherstripping there but...
Clyde65
Rebuild of Clyde
support our troops!
Old 06-24-2019, 02:24 PM   #10
yote1234
yote1234's Avatar
Re: Tailgate bumper
i have the same problem... im watching....
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 06-24-2019, 06:06 PM   #11
nsb29
nsb29's Avatar
Re: Tailgate bumper
I’m working on mine, I need to look at that. I made a hard rubber bushing with a stainless pin for my hinge so it wouldn’t chip the paint. I know the chains will but I think they give them caricature. The chains not chips
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-25-2019, 02:51 PM   #12
damnyankee36
damnyankee36's Avatar
Re: Tailgate bumper
I was thinking of using that clear film that's used to protect the bottom of sheet metal, around wheel wells, front ends, etc. I'm sure it would have to be periodically replaced but it might save the paint. Even a few layers of heavy duty clear packing tape might do the trick.
Some sort of thick, adhesive tape might also work. Something thin enough that it doesn't make the tailgate stick out too much.
damnyankee36 is offline   Reply With Quote
Old 06-25-2019, 03:29 PM   #13
oem4me
Re: Tailgate bumper
Minimal searching found "friction reduction tape". Perhaps a couple short strips where your gate first makes contact would do the trick. I wonder if it's available in clear?
https://www.rockler.com/nylo-tape-fr...yABEgItkfD_BwE
Old 06-25-2019, 05:17 PM   #14
bigmoe
bigmoe's Avatar
Re: Tailgate bumper
Maybe a couple of pieces of some medium density foam tape that will almost fully collapse when the gate is shut?
bigmoe is offline   Reply With Quote
Old 07-02-2019, 12:24 AM   #15
Lokin4AReason
Lokin4AReason's Avatar
Re: Tailgate bumper
Looks nice
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
