06-30-2019, 06:57 PM | #1 |
Replacement Exhaust manifold plug size
Truck is a 1968, C20 with the factory 396. Left exhaust manifold cracked so I bought a replacement and installed it. The new manifold has the AIR holes and the large threaded home near the exit point. I have straight pipe plugs in the 4 AIR holes, and that works great.
Any idea what size and thread the hole is near the exhaust exit? Posted via Mobile Device |
06-30-2019, 08:10 PM | #2 |
Who Changed This?
Re: Replacement Exhaust manifold plug size
Do you have a picture? I'm not familiar with anything but the 4 A.I.R. ports and the exhaust port. Maybe it's for an Oxygen sensor?
06-30-2019, 08:23 PM | #3 |
06-30-2019, 09:13 PM | #4 |
Actually for the smaller tube holes, the size is 5/16'' tubing plug. If you tighten the pipe plugs too much you can crack the manifold. Yeah, big hole is for an O2 sensor. Size as stated---should have had a plug in the box when you purchased it, just like mine did
06-30-2019, 09:55 PM | #5 | |
I didn’t use tapered pipe thread I used straight pipe thread. So it wouldn’t tight and has to use something to lock the threads in place. Posted via Mobile Device |
06-30-2019, 11:29 PM | #6 |
Who Changed This?
There are 5/16" plugs that have the same thread as a tubing B-nut, and have the inverted flare on the end to match what is machined into the exhaust manifold. Straight pipe plugs will probably work fine, though I haven't ever done it that way. Looks like you have a universal manifold that fits a ton of years.
06-30-2019, 08:12 PM | #7 | |
Looking for the plug that is pictured on the left side of the photo. Posted via Mobile Device |
07-03-2019, 09:37 AM | #8 |
Found a oxygen sensor plug yesterday and it fits great. One quiet ride again.......
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
07-03-2019, 09:49 AM | #9 |
Who Changed This?
Excellent!
