07-09-2019, 09:10 PM | #1 |
V8 engine mount help
I have a 68 with a 327 v8 and a factory 3 speed on the column that I have owned and drove for the last 30 years. I have pulled the sbc to install a 700r4 transmission and a few other upgrades. I am looking for some help with the engine mounts that bolt to the frame, they are in the “back” holes, I believe it originally had a 6 cylinder.
Can I use the current engine stands and move them to the front holes with the same engine? I moved them ahead after I pulled the engine but have not reinstalled the engine yet. Would they be the same? The only thing I can see I need to do is to drill a new hole for the bottom bolt on each side of the front frame cross member. Thanks for any help.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
07-10-2019, 06:30 PM | #2 |
Re: V8 engine mount help
No the six cylinder mounts you have are shaped wrong for the front location. You need to get V8 mounts and mount them to the front holes on the frame and cross member.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
07-10-2019, 08:57 PM | #3 |
Thanks appreciate the help.
07-11-2019, 06:16 AM | #4 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-11-2019, 03:52 PM | #5 |
Thanks Katrina/10,
That’s what I was planning to do and was going to check it out before I purchased new ones. Thanks! Posted via Mobile Device |
07-11-2019, 05:03 PM | #6 |
I know what you want to do will work, but remember I have no idea whether it locates the engine in exactly the right place. I had to relocate the transmission crossmember for the 700R4 so that didn't matter. Maybe someone who actually knows the difference will respond.
