Old 07-10-2019, 04:25 PM   #1
Livemeyer
Livemeyer's Avatar
Old Skool wiper arms
Wow. When old guys say they don't make things like they used to, these wiper arms are exactly what they're talking about. I don't even think my wipers work, but before I even get that far I thought I should at least have some new wipers on there to act the part. So I bought these Trico wipers from Advance Auto Parts, shipped to my home, $9.99 each. They say they fit blade style with the adapter, or J-style. Well... my arms have a sort of blade style with a screw-in mount that change to a J-style. I thought it would be easy to replace these blades with these options, except nothing comes apart. Except of course, where it was intended at the spots with the screws. I thought I could get the J-hook to come out of the old wiper blade. No. I thought I could remove the round plate screw-in receiver from the blade arm. No. I even put a drill bit through the detent hole, I thought that was what was holding it on. Even after that, using a vice as resistance I still couldn't get the end to come off. It seems these parts, and this steel, is so tough I can't get it to come apart unless I destroy it. So what are my options? Are there reproduction arms I can get with J-hook or blade style?
Livemeyer is offline   Reply With Quote
Old 07-10-2019, 04:26 PM   #2
Livemeyer
Livemeyer's Avatar
Re: Old Skool wiper arms
Picture 2 and 3 are of the new blade, 1 and 4 show the original.
Old 07-10-2019, 07:21 PM   #3
mick53
Why can't you use OEM? I bet a bunch of people have an old set laying around and I would think the rubber is available. I have an old set at home but I'm not there.
mick53 is offline   Reply With Quote
Old 07-11-2019, 12:42 AM   #4
Livemeyer
Livemeyer's Avatar
I'm not sure what you mean by OEM. I'd like to keep using the wiper arms, but how to get new blades? As far as I know they don't just sell the blade alone anymore, particularly in an odd size like 10" or 12", or am I wrong? I mean, I did search common auto parts stores in my area. Or do you mean OEM like go to the Chevy dealer? I doubt that's where I'd find them. I suppose I can try searching again, this just happened to be what came up on Advance Auto and it indicated these Trico style were replacements for the original style, but apparently not. I guess I'm trying to figure out just that - are these ones with the screw the factory original style? Or do I have something "uncommon?"
Actually, I thought I'd go the route you mentioned, using just the replacement rubber. So I removed the rubber from the new 12" blade and put it in the old. Clearly, that wasn't ideal, as the originals are 10".
I found a listing for the same Trico classic wiper blades but in 10" size on eBay, but that's going to cost me $30 for the pair, and I'd still have to pull the rubber out and use them on the original mounts. https://www.ebay.com/itm/Trico-Class...oAAOSwf~9ZYM7e
When I ask Advance Auto Parts for a new wiper blade to fit a 1951 Chevy Truck, I get this: https://shop.advanceautoparts.com/p/...m=wiper+blades
Or this, which is what I ordered: https://shop.advanceautoparts.com/p/...m=wiper+blades
Old 07-11-2019, 12:48 AM   #5
Livemeyer
Livemeyer's Avatar
I took a look at Brothers Trucks and they sell a complete set of wiper arms and blades for $50.
https://www.brotherstrucks.com/47-53...tinfo/WAS7253/
I didn't think I needed to go that route since my arms are in pretty good shape, but maybe that's what I gotta do to get the blade type mount for the wiper.
I guess what I'm really looking for here is, has anyone ever seen this screw type end? And did they figure a way around it, or did they use it?
Old 07-12-2019, 12:14 AM   #6
mr48chev
mr48chev's Avatar
When I was out taking my sunset photos I took a shot of the original wiper arm on the 51 cab I moved back under the trees today. Name:  IMG_4890.jpg
My ongoing truck projects:
