Old 07-13-2019, 08:41 PM   #1
DEAK71C10
71 C10 Manual Transmission Mount
Having a hard time finding transmission mounts for a 71 C10 with 307 motor with a standard transmission (3 on tree). I’m thinking of just putting the original mounts back on, even though the rubber is dried out and they are showing their age.
I talked with Tech at LMC and he indicated there seems to be an after market mount that does not resemble this part at all. If any members have replaced them and remember where you got them, it would be great to know. I did a search here and did not find any info relating to these mounts. They are on a crossmember, one on each side, the mounting block resembles a “C” with a large center hole that sits on a hole in the crossmember and two bolt holes in the mount for securing to the transmission.
Does the same mount work for both manual and automatic transmissions? Parts sites don't seem to distinguish or ask if manual or automatic, and only show one mount, and that appears to mount on the center of the crossmember. Not sure how that would bolt to the transmission though. Any help or info appreciated.
The crossmember, circled in red are the location and one mount:
The Mount, top and bottom:
DEAK71C10 is offline   Reply With Quote
Old 07-13-2019, 09:21 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 71 C10 Manual Transmission Mount
Ebay $65.00 a set I think I saw them in Classicparts also
https://www.classicparts.com/1954-84...info/79%2D111/ rubber
https://www.classicparts.com/1954-84...info/79%2D161/ poly
Old 07-13-2019, 09:56 PM   #3
Wrenchbender Ret
They should be available at any parts store. The same one was used for many years. There is also a small mount that goes underneath the frame. There is a bolt & spacer sleeve that holds it all together. Often they have fallen out & are missing. The auto tans models are different.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-14-2019, 07:28 AM   #4
DEAK71C10
Thanks Grumpy & George, will search around. Wonder why they are called an engine mount. Looks like you have to drill and tap new holes for bolting on.
Old 07-14-2019, 08:07 AM   #5
Grumpy old man
You don't have to drill and tap anything , The bolt and sleeve you re-use the old ones . These mounts are only used on the stock type bell housing . the bolt size is 1/2 x 18 x 3 1/2" .
Just for general knowledge the 6 cyl and V8 manual cross members are different and mounted in different positions .
Old 07-14-2019, 08:12 AM   #6
Grumpy old man
stock bell housing
Old 07-14-2019, 07:29 PM   #7
DEAK71C10
Very good Grumpy, thank you, will do.
Old 07-14-2019, 09:57 PM   #8
ElKotze
ElKotze's Avatar
I found them under rear engine mount, since manuals are not mounted to a cross member, they just bolt to the bell housing, which is resting on said rear engine mounts. You can see it very good in Grumpy's pic. That's why when you search for trans mounts, all that comes up are mounts for automatics.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 04-11-2021, 03:01 PM   #9
phlegm
Still Green but learning
phlegm's Avatar
Resurrection of this one, I need to replace the clutch on my 3 speed and I am going to do the gaskets on the gear box while I am at it. Looking under there planning and I see the transmission mounts have a little clip on them. I guess it's designed to keep the bolts from backing out. How do I get those bolts to back out of that mount do I remove the clip somehow?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-11-2021, 05:00 PM   #10
RustyPile
RustyPile's Avatar
Just flatten the tab that's bent up (down?) against the bolt head.. Remove the bolt with a conventional wrench or socket.. The bolt threads directly into the bell housing ear..
RustyPile is offline   Reply With Quote
