Old 07-18-2019, 12:31 AM   #1
WB72
Before and After
WB72's Avatar
Lets see your Air Management Systems.
How did you set up your air tanks and compressors?
Are they accessible through the bed?
Bed lifts?
I want to see them all, good ideas and those that you regret for whatever reason.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-18-2019, 03:26 AM   #2
EVRLET
EVRLET's Avatar
Re: Lets see your Air Management Systems.
Neatly tucked under the raised floor
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 07-25-2019, 10:28 PM   #3
WB72
Before and After
WB72's Avatar
Nice Idea, How did you determine where the lift rams were to be placed?
Is it just a standard hinge? is the entire bed floor removable if you need to work on the system?
66,000 miles.
Alberta, CANADA
Old 07-26-2019, 02:05 AM   #4
EVRLET
EVRLET's Avatar
The gas shock placement had to do with height on opening and smooth operation on closing.
The hinge system is the same as a hard tonneau cover, but modified slightly for my application.
Yes, the floor is completely removable and I have used it as a picnic table once. One end stayed on the truck and I had two makeshift legs for the other side. I slid it out to where I needed it and had a good ol time at a truck meet.
Old 07-26-2019, 07:55 AM   #5
Simple10
Simple10's Avatar
I wanted an air ride set up on big red, until I was quoted starting price of 9k in Australia
Simple10 is offline   Reply With Quote
