07-18-2019, 07:55 PM | #1 |
My 4" drop axle
Pete and Jakes sent me some pictures of my 4" drop axle they had Super Bell make for me. My spindles are being altered and I'll send them to them. Then they can finish it.
07-18-2019, 10:02 PM | #2 |
Re: My 4" drop axle
4" drop is a lot. hope you don't drag the axle on the pavement. What size wheels will you use?
07-18-2019, 11:03 PM | #3 |
Re: My 4" drop axle
07-26-2019, 01:30 AM | #4 |
Re: My 4" drop axle
I hate to bring up a troubling question but I always thought that chroming a dropped axle induces hydrogen embrittlement? If so, obviously a potentially fatal flaw if it ever fractured.
If I were the OP I'd ask the question of Pete & Jake's, "How was this addressed/prevented?"
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-26-2019, 10:35 AM | #5 | |
Re: My 4" drop axle
07-26-2019, 02:14 AM | #6 |
Re: My 4" drop axle
Cute but no thanks. I don't want any welded axle on anything I drive. Plus is it a 4 inch drop over a stock axle or just 4 inches from straight?
07-26-2019, 04:36 AM | #7 | ||
Re: My 4" drop axle
You guys believe in chemtrails too? Maybe the grassy knoll Kennedy assassination theory? Get serious. |
07-26-2019, 04:19 PM | #8 | |
Re: My 4" drop axle
I know Pete and Jakes has been around 40+ years, they have made more axles than probably anyone, so I have to believe they know what they are doing and it will be a fine axle. But I just have to question about the drop amount, it doesn't look right to me. On the last photo you posted it looks like from the top of the spring mount if a straight edge were ran over to the king pin mount it looks like it would only be a few inches between the straight edge and the bottom of the axle where the king pin goes. On the photo I posted which is only a three inch drop (over stock) that distance looks further, three inches or so at least. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" Last edited by MARTINSR; 07-26-2019 at 04:32 PM. |
07-26-2019, 07:32 PM | #9 | |
Re: My 4" drop axle
07-27-2019, 09:23 AM | #10 | |
Re: My 4" drop axle
Thanks |
07-27-2019, 11:40 AM | #11 | |
Re: My 4" drop axle
https://droppedaxles.com/ Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
07-27-2019, 02:04 PM | #12 |
Re: My 4" drop axle
You will want to talk to Jerry at "Pete and Jakes". I sent them an original axle off a 53 1/2 ton I had laying around so they could get all the angles like a stock axle. They are great to work with. They sent me Ford spindles to have altered. I have Wilwood 12.88" six piston Nickle plated caliper drilled and slotted 5" 4 3/4" disk brakes. They don't make these for Ford spindle. I bought Heidts 2" drop spindles for a 57 Bel Air that have the proper spindle pin profile and the pin is pressed in. My head engineer who also owns an industrial fab company is going to do his voodoo and put the Heidts pin in the Ford spindle. I will then send them back to P&G and they can finish the front end. I will then have to fab a caliper bracket. Thanks to Jerry at P&J and Josh at Wilwood it has went smoothly. It's the journey. Thank you for your time.
07-26-2019, 07:24 PM | #13 |
Re: My 4" drop axle
Brian is correct, that is just their Ford dropped tube axle that they welded perches for leaf springs on and sent to the chrome shop. The only thing they did "custom" was to weld on those pieces of steel to set the parallel springs on but they left the Ford spring perch eyes rather than scratch build you a custom axle minus the ford pieces. That will cost some show points. At the cost of their shop time you probably didn't pay that much to have the pads welded on as the same chrome axle without the pads is 955.35 list in their catalog.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 07-26-2019 at 11:15 PM. |
