07-19-2019, 04:25 PM | #1 |
Hunting an original style air cleaner “elbow”
Like the title says, I’m hunting the rubber boot/elbow that goes from my original equipment air cleaner assembly to the hole in the core support. It’s for my ‘87 TBI truck.
I’ve added a picture for reference. |
07-19-2019, 05:42 PM | #2 |
Re: Hunting an original style air cleaner “elbow”
man, good luck...i have spent several hours today looking my self.
i am retro fitting an inlet to make a dual intake, and would like the factory tubing... i even went as far as to search for the older summit/jegs tbi power package, NO LUCK. if i find something, i will post it here |
07-19-2019, 05:45 PM | #3 |
07-19-2019, 05:54 PM | #4 | |
07-19-2019, 05:58 PM | #5 |
i doubt the tube differs that much, i am going to purchase 2 and fit them to my 89 once i finish the mod.
07-19-2019, 06:12 PM | #6 |
If I hadda known..I threw 2 of them away....
07-19-2019, 07:00 PM | #7 |
This style was only made in 87 and 88, and are not currently reproduced.
Go to car-part.com Enter search for 87 and 88 suburban. There are really no results for just an air tube so select Air Cleaner. I guess they don't think its worth listing. You will get a bunch of results. Some even have pictures. Look through the pictures and pick out the results that show the air tube in the engine bay, and start calling. A lot are cracked, so you need to make sure they inspect the tube. You might have to get them to do a package deal of the air cleaner and tube together. In my case, I ordered the air cleaner and they threw in the tube for free. |
07-20-2019, 10:35 AM | #8 | |
07-20-2019, 01:05 PM | #9 |
Good luck guys. Please post if you find something. I ended up w/an open element set-up as I couldn't find what I needed for my 89 CC Dually set-up.
I've been looking at alternative air cleaner housings (OE & not the Spectre aftermarket looking stuff) that I can adapt 4" hosing to. I was successful after being tasked w/a similar set-up for a car so I began the hunt again for my dually.
07-20-2019, 10:34 AM | #10 |
Gahhhhh!!! Greg! You’re killin’ me man!
07-20-2019, 02:40 PM | #11 |
Sorry Carter....I got tired of tripping over em....haha
07-21-2019, 09:56 AM | #12 |
I have a good one pulled from an 88 Suburban. $45 shipped. I will check to see if I have another one on my 88 dump truck.
07-21-2019, 10:55 AM | #13 |
I pm’ed you...
07-22-2019, 08:11 AM | #14 |
The LMC 81-86 is straight for the carb set, the 87 TBI hooked because the air cleaner base nose is shorter @ different angle. (87 TBI air cleaner base, needs the 87 TBI air inlet tub to work.)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
07-22-2019, 08:32 AM | #15 |
LMC does sell two one is longer I think you might make it work by modifications to it.
Maybe fill towels one end shape the angle heat the tube enough with a heat gun to relax plastic let cool in that shape you need should hold to it better) try not to melt it. your best bet for one would be scrap yard that has 87 gas TBI
07-22-2019, 10:07 AM | #16 | ||
07-22-2019, 11:50 AM | #17 |
KrazyRay has come to the rescue again. Ray has helped me out numerous times in the past.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
07-22-2019, 04:02 PM | #18 |
TKCR... You have helped a bunch of members here also. This is a great site!
07-22-2019, 10:54 PM | #19 |
Those are pretty rough to find, Much like the 81 Under Vaccum Style Inner Fender-mounted Cruise control units... If it was a 6.2L diesel they are nearly impossible to find... Luckily I found one for my 6.2 in my "parts" stash... haha.
I would think B/c It's on a Gasser Some Aftermarket company would sell them. Should be all the Same for Carbed or TBI. |
