Seat back will not told forward???
I just picked up a very nice 1969 GMC Custom. The seat back will not fold forward. Do they not fold forward? My 68 Chevrolet did.
![]() Join Date: Jun 2014
Re: Seat back will not told forward???
I believe that 67-68 were the only ones that folded, starting in 1969, they did not fold anymore.
![]() Join Date: Dec 2013
67-early 68 fold safety regs in 68 required the seat to be bolted so 68-72 don't fold .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#4 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#5 | |
It looks like the design still allowed for the fold. I bet it wouldn't take much to make the later seats fold.
Can anyone tell me how to fix it so I can fold it forward to get to the gas gauge sending unit on my 72?
George |
push the seat all the way forward and lean over , You can't make the Non folding seat lean forward without loosening the material at the back bottom corner and then removing the #3 phillips screws from the legs that hold it to the bottom frame and you take the risk of tearing up the seat material . if you can't get the access you want by moving the seat forward remove the seat to floor bolts and lift the entire seat out .
Here are a couple pictures of the folding seat back from a 67 truck , Notice the the upper frame is wider than the seat frame to allow the top to fold without damaging the material ,Also the single pivot shoulder bolt , Along with the "latch" mechanism using a wing nut to secure the seat from folding forward . You can also use the "latch" bolt to adjust seat back lean for comfort .
#10 | |
