Old 08-02-2019, 02:37 AM   #1
Nightrider
Nightrider's Avatar
Tire size on lowered c20
Hey guys I have a 1984 c20 Scottdale with the Detroit diesel. I have a couple questions.. I did a 3 inch hanger and shackle lowering on the back and kept the front stock looks good. I'm running 285/65/17 (33inches) I'm really wanting to lower it more and was thinking of doing a axle flip kit on it. Would the tires rub on the bed? I also pull a trailer with my car on the back every other week. Is that even possible? To pull and still be that low? Need yalls wisdom and advice! 😊
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 08-02-2019, 04:21 PM   #2
tinydb84
tinydb84's Avatar
Re: Tire size on lowered c20
Before I cut mine up I ran shackles and hangers and pulled 3 or 4 leaf springs from the bottom of the pack. Got a 5-6'' of drop. The spring back is so thick if you do a flip kit you will be in the 8ish inch drop range. You will absolutely need a c notch and that would seriously inhibit your ability to tow.
David
Instagram: myfabguy
Old 08-03-2019, 01:47 AM   #3
Nightrider
Nightrider's Avatar
OK good to know I believe the lowering ones I received were for a c10 and a little different. Maybe I'll look into a lower hanging kit and removing a couple leaf springs.. And would be able to tow.. Orrr should I go back to factory hight and do a axle flip kit???
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-03-2019, 02:06 AM   #4
Nightrider
Nightrider's Avatar
Here are a couple pics of my truck👌
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-03-2019, 02:12 AM   #5
Nightrider
Nightrider's Avatar
Phone has been acting weird sorry guys.
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-03-2019, 07:40 PM   #6
LT7A
Not to be too much of a smart, uh, aleck, but I think your last picture answers your own question. It doesn't appear that your 285s have much room to move before they're going to be pulling your fender trim off for you. A narrower tire that can tuck behind the fender lip would probably allow you to get another inch or two.
On the "opinion" side of things, a 3/4 that still tows and hauls needs to have suspension travel. Sometimes the good answer is to have things in proportion, rather than trying to go as low as you can. Good sideview pictures of your truck loaded and unloaded (not towing and towing) would help us give subjective answers to what you can do. Without seeing more, I would say you can't lower it further in the back and that an inch lowered in the front front might be all it takes to give it good proportions.
Old 08-04-2019, 01:57 PM   #7
Nightrider
Nightrider's Avatar
I got ya. Thank you for your info. I'll send better pics😏 I would change tires but I'm getting new toyos the same size for free and don't want to pass it up.
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-04-2019, 02:13 PM   #8
Nightrider
Nightrider's Avatar
Here is another pic
Old 08-04-2019, 02:31 PM   #9
Nightrider
Nightrider's Avatar
So if I did not tow my car anymore think I could go lower or still running into the problem of the tires to wide?
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-05-2019, 12:09 PM   #10
SCOTI
SCOTI's Avatar
Nope. Still going to make contact most likely w/the wheel set-up & the tall tires.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
