Old 08-03-2019, 09:42 AM   #1
RestoreAmerica
Stick to Automatic Transmission Swap
What is needed for the swap?
Steering Column
What else?
RestoreAmerica is offline   Reply With Quote
Old 08-03-2019, 09:54 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Stick to Automatic Transmission Swap
5 Minutes in a dark room to reconsider ?
https://www.youtube.com/watch?v=8wWpYmqf_lE
Old 08-03-2019, 09:54 AM   #3
Smitty
Smitty's Avatar
Do a search! There is a ton of information on this. Did this myself 20 yrs ago. But can’t remember everything. Shift linkage, starter, flex plate, radiator, drive shaft, remove clutch pedal, rewire neutral safety switch, transmission crossmember. Just a few.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is online now   Reply With Quote
Old 08-03-2019, 07:59 PM   #4
LuckyScott
LuckyScott's Avatar
Im getting ready to do this myself. 1970 C10. Currently has the old top loader 4 speed with granny gear. I want a 700R auto with over drive.
So first I have to change the steering column. Then there is a company called Koogle that sells a rod to make the trans shift with the stock auto gearshift.
LuckyScott is offline   Reply With Quote
Old 08-03-2019, 08:29 PM   #5
geezer#99
geezer#99's Avatar
You mean Kugel Komponents.
Tranny hook up is the easy part. Biggest pain is removal of the bellhousing crossmember. Those rivets are in a bad spot.
geezer#99 is online now   Reply With Quote
