08-05-2019, 11:58 PM | #1 |
Hinge bolt length
I am putting my doors back on my truck (finally!) and I am finding that I have two different size hinge bolts. I have a few shorter ones, and bunch of the longer ones. The only clearance issue I can see would be the upper door bolts could possibly hit the window mechanism. Then I have several with the pointy tip, as seen i the last picture. Is that for something else?
Thanks in advance for the help.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
08-06-2019, 01:31 PM | #2 |
Re: Hinge bolt length
anybody able to help with this?
08-06-2019, 09:29 PM | #3 |
Ttt
08-06-2019, 11:06 PM | #4 |
The Older Generation
There should be plenty of room to use the longer bolts. They will be nowhere near the window mechanism. LockDoc
08-07-2019, 02:26 AM | #5 |
Pointed bolts are 67
Shorter bolts are suburban 3rd door Longer bolts fit the remainder yet all will fit without issues. |
08-07-2019, 07:46 AM | #6 |
That's weird, I've never had a 67 or a Suburban. But these trucks had a lot of parts from other trucks on them so maybe somebody just had a box of bolts
08-07-2019, 07:47 AM | #7 |
Thank you both for the feedback. One more question: what size are the bolts for the hood hinges?
08-07-2019, 12:06 PM | #8 |
The original door bolts off my 1971 are (GR 5) recessed hex bolts with spin washers. The bolt threads are 3/8-24 x 1.1/8". They're stamped double F.
You can buy black oxide replacement bolts off Ebay, and they're expensive. They claim they have the correct markings, but no, they just have three slashes for grade 5. They're shorter than original, maybe 1" long, but should work. The hood hinge bolts off the same truck are (GR 5) recessed hex, tapered end bolts with spin washers. The bolt threads are 3/8-16 x 7/8. They're stamped "ELH" or "E".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-07-2019, 01:52 PM | #9 |
Thanks, Tony!
08-07-2019, 09:55 PM | #10 |
well, I found two Hood hinge bolts in my stash and I cleaned them up though now we just need to find six more!
08-08-2019, 12:27 PM | #11 |
You can get a front end bolt kit that includes hood hinge bolts, all black oxide. I picked one up for $35 off Classic Parts.
08-09-2019, 12:10 PM | #12 |
Regarding the original question, some of the hinges are stepped, some are not. In other words, some are thicker than others. I'm assuming the thicker ones used slightly longer bolts. I don't know why or what years.
08-14-2019, 11:49 PM | #13 |
I have the "thick hinge". The OEM replacements I bought work alright, but there's not enough thread for shims. In other words, they're the wrong bolts. My original bolts (not-tapered (Randy)) are 1.1/8" under the spin washer. The replacements are 7/8ish, they might declare an inch.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-14-2019 at 11:58 PM. |
08-09-2019, 12:26 PM | #14 |
I stated the differences in bolt length, its not due to he difference in those hinges.
