Old 08-11-2019, 12:08 PM   #1
Mts67C10K20
Mts67C10K20's Avatar
Rear leaf question, why did they do this
My 67 k20 has the rear axle set back in the wheel well
I thought it may have the wrong springs on it
But in shopping for new ones I find that the lighter springs
Are 24" from front eye to ctr. Pin and the heavier springs are
26" to pin
This truck is 7500gvw
My question is why
and does someone sell heavy springs that Center the axle
Thanks in advance
Mts67C10K20 is offline   Reply With Quote
Old 08-11-2019, 02:00 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Rear leaf question, why did they do this
Never seen one that bad off factory....did you change something?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-11-2019, 02:10 PM   #3
Mts67C10K20
Yup that's why I'm looking for a heavy set of the 24 to pin
Installed a 14bolt but was the same with the H052
Springs are 52 long 26 to pin
Mounts are all riveted
Old 08-11-2019, 06:00 PM   #4
MySons68C20
MySons68C20's Avatar
It's hard to tell from the picture but how close is your bed to the cab?
MySons68C20 is offline   Reply With Quote
Old 08-11-2019, 06:43 PM   #5
Mts67C10K20
Have the cab off right now
Nearest I can remember it's a good inch
The bed seems to be squarely on the mounts
Still wondering why the 2 inch difference in pin position between the 1/2ton and 3/4ton springs
Old 08-11-2019, 07:09 PM   #6
mongocanfly
Is the center spring pin equal distance from each spring eye?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-16-2019, 03:48 AM   #7
Richard
I agree with the person asking about bed position. Looks like it is almost touching the cab.
Richard
Old 08-18-2019, 08:41 PM   #8
sweetk30
sweetk30's Avatar
you could also do this item for the fix . but as said box looks to close to cab . or its the angle the pic was taken .
http://offroaddesign.com/catalog/Axl...%20Plates.html
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-19-2019, 05:13 PM   #9
Mts67C10K20
Finaly got time to get back to this and I'm afraid I trusted my memory and made a mistake
Re measured the spring pin distance and discovered my problem
My current springs are 28" and should be 26"
So a set of correct springs will fix things nicely
Or possibly the spacers suggested by Sweetk30
Thank you all for your intrest and suggestions
Old 08-20-2019, 04:18 PM   #10
sweetk30
sweetk30's Avatar
funny you say 28" springs .
i just scored a dana 70 drw wide axle from a mid 70's gm cut-away van motor home body . it had the leafs on it and there real nice shape but there 28/28 eye to eye .
Old 08-26-2019, 01:21 PM   #11
Stormin08
Stormin08's Avatar
you have 2 things...
1. you bed is off, or
2. possibly your springs are flipped
generally, they have a shorter and longer side ( eye to eye), make sure they are correct and havent been changed before.
Stormin08 is offline   Reply With Quote
