Old 12-02-2003, 02:34 AM   #1
skokie
skokie's Avatar
Engine Valley Pic
If anyone has a pic of a 350 engine valley can they please post it?
Thanks again
skokie is offline   Reply With Quote
Old 12-02-2003, 02:41 AM   #2
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
You mean the valley under the intake?
Cat Fuzz is offline   Reply With Quote
Old 12-02-2003, 02:45 AM   #3
skokie
skokie's Avatar
Yep especially looking at where the heads and intake meet.
Old 12-02-2003, 02:50 AM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I might be able to do that. Gimme a few minutes. Don't know if my dead 350 is accessible.
Old 12-02-2003, 03:03 AM   #5
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Ok, took a bunch of pics. They're about 3 megs for all of them. If you tell me what your looking for, I can probably pick one or two of these and send.
Old 12-02-2003, 03:07 AM   #6
skokie
skokie's Avatar
I am looking for a pic of where the intake manifold would sit up against the head.
Old 12-02-2003, 03:18 AM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Any of these help?
http://www.users.qwest.net/~fsr1/intake1.jpg
http://www.users.qwest.net/~fsr1/intake2.jpg
http://www.users.qwest.net/~fsr1/intake3.jpg
http://www.users.qwest.net/~fsr1/intake4.jpg
Old 12-02-2003, 03:25 AM   #8
skokie
skokie's Avatar
Yep they do. This is a 350? What kind of heads are on there? Reason I ask is this. Look here at the pics of my manifold.
http://67-72chevytrucks.com/vboard/s...threadid=79191
Especially the side shots. On the manifold there is only 4 sets of holes and on your engine pic there is 5 sets. Hmmm
Old 12-02-2003, 03:30 AM   #9
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
The water jackets on the dizzy end of the engine don't pass over the intake. The intake blocks them off.
Old 12-02-2003, 03:37 AM   #10
skokie
skokie's Avatar
Ok newbie alert (i warned ya what are water jackets. So let me see if I follow you here. In the pic circled in white is the dizzy side and that is blocked by design by the intake. What about the ones circled in red? Can you take me through what a intake does?
Old 12-02-2003, 03:41 AM   #11
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
The ones up front, circled in red, is where the coolant exits the block thru the thermostat and then into the radiator. There are water jackets at the rear, circled in white, so the heads will be the same on each side. Otherwise, there would be right side and left side heads.
An intake manifold simply distributes the air/fuel mixture to each cylinder. Also, that little port in the middle is an exhaust gas crossover to help the carb warm up faster.
Old 12-02-2003, 03:43 AM   #12
skokie
skokie's Avatar
What about the 2 pairs? What do they do?
Old 12-02-2003, 03:43 AM   #13
Rooster's 67
Rooster's 67's Avatar
Standard water flow in a stock gen 1 small block is radiator to water pump to block flowing to the back,up into the head and then out of the heads at the front into the intake and through the thermostat and back into the radiator,,,,the heater has to be tied in on the suction side of the pump and pressure side of the pump....IE: off of the intake and back into the water pump(water pump is the return and the intake side is the supply to the heater).The back is generaly plugged or is threaded for heater tap (rather than using one of the front fittings)
Rooster's 67 is offline   Reply With Quote
Old 12-02-2003, 03:47 AM   #14
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Those are where the air/fuel enters the heads. If you look down thru where the carb mounts, you should be able to see thru.
Old 12-02-2003, 04:00 AM   #15
skokie
skokie's Avatar
Yep Gotcha. Man this is all starting to come together now. Thanks again
Old 12-02-2003, 12:27 PM   #16
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Skokie,
I'm glad you asked these questions
<--Newbie too! I've been working on my engine (first time) with my mechanic brother-in-law and he's no 'teacher'. I ask a lot of questions and he just goes 'don't worry about that'. I figure if I learn while we do this I won't need as much help the next time.
Good Luck!
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
