Old 09-03-2019, 09:09 PM   #1
BCOWANWHEELS
1.6 ratio rocker arms
Any of you guys run the 1.6 ratio rockers.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-04-2019, 09:09 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 1.6 ratio rocker arms
Not on factory heads...Read this, http://nastyz28.com/threads/1-6-rock...-engine.95912/
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-04-2019, 11:59 AM   #3
BCOWANWHEELS
They fit and work perfect............ You have /should enlarge the pushrod holes in the heads though and run guide plates which i have done the mods to go along with my lt1 cam. My only concern is will they fit under stock steel valve covers without spacers. I want stock appearence as possible.
Old 09-06-2019, 10:02 AM   #4
rcazwillis
I have used 1.6 rockers under stock valve covers. Never used an lt1 cam, but have used comp cams.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 09-04-2019, 11:44 PM   #5
I haven't run my 327 with them, but my machinist chose the parts and put my LT1 aluminum valve covers on. He wouldn't have if there would be clearance issues.
Old 09-05-2019, 01:47 AM   #6
BCOWANWHEELS
Lt1 alum covers most likely are taller than stamped steel. I,ll know 4 sure in a day or 2 and post it
Old 09-06-2019, 07:06 AM   #7
They don't look tall to me. I can measure. I think tall valve covers are an aftermarket think
Old 09-06-2019, 10:00 AM   #8
rcazwillis
Yes, I have used them on multiple SBC engines without guides. Will they work on your engine? What are the details? Cam specs, valve springs, ect. They should work, but details will determine the correct answer.
Zane's 71 Build
Old 10-23-2019, 11:49 PM   #9
BCOWANWHEELS
Fyi , roller tip 1.6 rockers work under stock valve covers
