Old 09-07-2019, 10:23 AM   #1
CJ2A
CJ2A's Avatar
Quality Seat Belts
I am finishing up a 1963 GMC build for my daughter. I want to learn from some of you’re experiences. The wife is wanting seat belts with a shoulder strap installed.
Can I get some pros & cons on the aftermarket seatbelts available ? I am more into Quality than price. Is the mounting of the shoulder strap solid even though it is just a drilled hole in the cab ?
CJ2A is offline   Reply With Quote
Old 09-07-2019, 02:39 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Quality Seat Belts
In the FAQ section there are posts about seat belts:
http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Aftermarket Seatbelts???
a long thread about seat belt options
Seat belts for stock bench seat, purchase and install info
a thread with information about a aftermarket seat belt kit for a bench seat, with photos.
1965 Seat Belts??? : July 2010 /60+ posts
anybody make the seat shoulder bolts : November 2013
1966 shoulder strap cab holes : April 2011
Seat belts???? : August 2014 /+15 posts, some photos and scanned diagrams
(what is) the best 2 point retractable seat belt? : September 2014
66' 3 Point Seatbelts_B Pillar Plug... March 2014
Old 09-07-2019, 11:32 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
The aftermarket 3-point seat belt conversion kits are a good idea. Be sure to use all of the backing hardware (the hardware that mounts to the rear of the panels) during the installation - the back side of the floor mounts and the B-pillar shoulder harness mount.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-01-2019, 07:24 AM   #4
Afirehawk1
How is everyone installing the seatbelts if the pillar plug or nut brace is missing?
I must have an early 66.
I see the measurements but was curious best way to install.
Afirehawk1 is offline   Reply With Quote
Old 10-01-2019, 09:21 AM   #5
roll_the_dice
roll_the_dice's Avatar
Here are the specific links to seat belts in the FAQ...scroll down a little.
http://67-72chevytrucks.com/vboard/s...55&postcount=4
Also, you would need a hardware kit from wherever you buy your seat belts. Something like this...
https://www.seatbeltsplus.com/PROD.h...ode=FHD-1046-1
Lastly, the best install thread I found was from LugNutz on this board. His website on the install is here...
roll_the_dice is offline   Reply With Quote
Old 10-01-2019, 01:14 PM   #6
Afirehawk1
Perfect
Old 09-08-2019, 10:11 AM   #7
roll_the_dice
I am about to order 2 shoulder belts and a middle lap belt for my 65 from www.seatbeltsplus.com. They are $225 and about $70 cheaper than other sites I have looked at.
Old 09-08-2019, 04:24 PM   #8
The Rocknrod
Moderator
What buckle length are you getting and do you have a bench seat?
Old 09-08-2019, 05:01 PM   #9
roll_the_dice
I do have a bench seat. 20" no sleeve buckle. I am afraid the 12" sleeved buckle wouldn't be long enough.
Old 09-08-2019, 05:58 PM   #10
The Rocknrod
Moderator
Keep us posted, I'd like to know on the length. On they're catalog on page 5 they show cable type buckle in 6", 12" 18" and 22".
Old 09-10-2019, 12:15 AM   #11
slepysal
slepysal's Avatar
I am running some surplus Military Hummer 3 point belts that were purchased of E Bay about 4 years ago
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-10-2019, 09:31 AM   #12
roll_the_dice
Any pictures or other info on who you bought them from on ebay? I looked and mostly saw belts made in China... do you remember the length of your belt and buckle? Thanks
Old 09-10-2019, 03:19 PM   #13
Gargoyle
Gargoyle's Avatar
Have you looked into Juliano's?
https://www.julianos.com/Seat-Belts-s/96.htm
Gargoyle is offline   Reply With Quote
Old 09-10-2019, 04:32 PM   #14
forestb
forestb's Avatar
That's where I got mine and am vary happy with them. Thankfully they have never been tested.
forestb is offline   Reply With Quote
Old 09-10-2019, 04:58 PM   #15
vin63
vin63's Avatar
Unfortunately, almost all of the webbing material comes out of China, which is why some of the long-time racing safety equipment makers like Simpson no longer re-certify their belts and offer discounts on new replacements. I do some custom stuff for a few customers on OE type belt replacements through DJ Safety/Deist Safety, where they still have a large stock of webbing that was made in the US for some of these period-correct restoration orders.
This is one I did for a 69 Pontiac Firebird.
50-year old originals left; new webbing right:
Old 09-17-2019, 10:41 PM   #16
slepysal
slepysal's Avatar
I can't remember the seller I can take a picture if you like
Old 09-18-2019, 06:34 PM   #17
roll_the_dice
That would be great. Thanks, I appreciate it.
Old 09-10-2019, 09:12 AM   #18
vince1
I think a collapsible steering shaft should be considered before the seat belt mod. In my other old car I won't put on the lap belt because the steering shaft has not yet been modified and in a front end collision, behind the wheel is not the place to be. I had an acquaintance who is not here today as a result of it.
An alternative to the 3 point harness is to change to a newer seat that has the belts built in.
vince1 is offline   Reply With Quote
Old 09-15-2019, 07:38 PM   #19
G8rN@te61
I used seatbelts plus and they turned out great
G8rN@te61 is offline   Reply With Quote
