Need advice: Dual Master Cylinder 64 C10
Hey guys,
Done a heap of searching but can't pinpoint what I need. I have a 64 C10 with drums all round and a single master cylinder. I'm upgrading to discs in the front and I'm on the lookout for a dual master cylinder. I want to keep it manual non-power. What do I need? Any master from a 67-72 C10? Plus a proportioning valve too? Was looking on Rockauto and there are few different masters to get, none specify exactly if they manual disc/drum or not: 71 dual: https://www.rockauto.com/en/moreinfo...29934&jsn=1475 70 dual: https://www.rockauto.com/en/moreinfo...29833&jsn=1588 And then get a prop valve separately from somewhere else. Or get a kit like one of these: https://www.summitracing.com/parts/clp-mcpvs-2 https://www.summitracing.com/parts/rsd-g0571 Note: I'm in New Zealand so there aren't many parts stores around here that sell what I need, rockauto is really cheap shipping here too. Thanks in advance! |
![]() Join Date: Oct 2009
Re: Need advice: Dual Master Cylinder 64 C10
If you go with stock parts, you'll want 71 or newer (70 and older were 4-wheel drum and the master cylinders are not the same). The summit links will work also.
Keep in mind that original did not have an adjustable prop valve. But nothing wrong with adding one instead of just a distrib/brake warning block. Personally, I'd buy a 71-72 C10 as in your very first link above (don't buy C20 or higher, they are different also...) NON-POWER brake master cylinder from a local parts store and add in an aftermarket adjustable prop valve and plumb your own lines. If you think you'll ever add a booster, now is the time to do it (and I'd recommend it), Captainfab sells a great bracket that tucks everything in close to the firewall. Just a thought (and you'd need a 72 C10 POWER brake master cylinder). |
#3 | |
Cheers |
Sounds good, hope it goes well. We're spoiled with shipping ease here (and I'm about 30 minutes from Summit's TX hub...
#5 | |
![]() Join Date: Oct 2006
When I had drums all around I used a master cyliner of of a 1967 drum/drum Impala. Worked great till I swapped out to disc brakes.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I think I installed a dual chamber non power brake master cylinder from a corvette. - Brian
Sorry posted above before I finished............. When I swapped to disc up front I went with a disc/drum 1977 vete master cylinder with power brakes
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 09-20-2019 at 11:38 PM. |
#9 | |
Cheers! |
#10 | |
Cheers, |
