09-15-2019, 09:39 PM | #1 |
Patching the dash that was cut for radio
I am getting interested in putting the dash back to stock after the PO cut it to insert a radio. What do I need to be aware of when shopping? What way should I go? Is a patch panel with the A/C center vent cutout difficult to get or are they pretty common? I have an 1969 CST/10 with A/C.
I see sometimes panels like this one richard2717 has listed in the parts section: And I see some that are smaller available new, like this: |
09-15-2019, 09:44 PM | #2 |
Re: Patching the dash that was cut for radio
And I should add: are there any members in the Houston TX area who know welding and would like to help me with this? Or recommendations of somebody who does this sort of body work?
09-15-2019, 09:46 PM | #3 |
a real dash cut of the size of the first pic is what you're looking for - it puts the welds mostly out of sight, behind the bezel and very little visible above/below the gb door, not all in the line of visible sight like the 2nd pic would require. Best source is the parts board, someone parting out a truck. I even got one in the original color of my truck on here (not that it matters, has to be painted anyway, but still )
09-15-2019, 10:00 PM | #4 |
I did one of mine a few months back and used an original section i bought off the board a year or two ago , I drilled the spot welds on the bottom and kept the framework intact . Welding and fill work is minimal this way compared to using an aftermarket patch panel .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-15-2019, 09:56 PM | #5 |
Would still need to cut out for the AC vent, unless rerouted.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
09-15-2019, 11:00 PM | #6 |
OK, since you have that whole dash completely out of the truck, can you describe what it's like to do that? I could just buy a whole dash. Also I have seen where people fill the slots and holes and end up with a dash that does not need a dash pad. How are slots and holes like that filled, and what is the difficulty level of doing that?
09-16-2019, 07:15 AM | #7 | |
09-16-2019, 07:36 AM | #8 |
I bought a cheap set of factory A/C vents that I'll trim off the back sides so they fit the dash face correctly and I'll be able to mark and cut the dash for the new vents and have them fit perfect. way better than using a paper pattern
09-15-2019, 11:59 PM | #9 |
Filling slots and holes on a surface that's as curved as that requires some really good welding skills.
I would do it as Jocko and Grumpy suggest. You'll have less welding and it will be in a less prominent area. The flat welds required for the aftermarket patch panel are an advanced skill.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-16-2019, 01:08 AM | #10 |
If your getting a used dash or section of one look carefully at the holes the knobs pass through. I have a center section that someone has removed the small step that the little buckets sit in. Without the steps you can't bolt the radio in.
If your looking to just bolt a stock radio in and not restore the dash you could do what I did here. Scroll to post 291. http://67-72chevytrucks.com/vboard/s...698377&page=12
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Tags |
cut, dash, patch, radio |
