![]() Join Date: Feb 2005
fuel door
Has any one ever installed a fuel DOOR onto a bed side. What I want to do is install a fuel door onto a bed that does NOT have one. That would be the inside as well. I have the donor bed, just need to CUT OUT the fuel door and weld it onto the NEW bed.
Vids would be nice if you got any. Thanks John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: fuel door
its been done one of the upstate NY fellows took part of my old bedside off to do just that.. im pretty sure he posted about it do a search
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: fuel door
I put a 2002 ford truck one mine just cut it out and weld it in
![]() Join Date: Dec 2009
Re: fuel door
Here is a good reference thread.
Member Rufas has a good pictures on page 2 at post#54 Link:http://67-72chevytrucks.com/vboard/s...d+in+fuel+door .
Moderator
![]() Join Date: Oct 2008
Re: fuel door
I can see doing this to add dual saddle tanks.
If you're mounting the tank in the back like the guys in the linked thread... can't you notch and reinforce any cross frame member that's in the way and use the fold down license plate mount from the 70's GM cars?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: fuel door
Just added information, This is my project truck (trazer) see my signature. What I am using is a blazer frame. Keeping the fuel tank where it is but I am going to put a bed on it. Because of the different types of frames "truck vs blazer" I have to cut the floor out and raise it up in order for the body lines to match the cab. This is where to fuel door comes into play. I have to relocate it, so I want to put in a fuel door. Confused yet,
![]() Thanks John
Re: fuel door
what ever donner truck you get the door off grab the upper plastic filler mount, steel filler neck and hard ware. Then you should be gold.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Re: fuel door
I did it on the passenger side. it was in my thread "rebuilding my 1977 plow truck" I recommend measuring the donor box for location and cutting out a large area from the donor. Cut as required, the smaller amount of welding you can get away with the better. remember to seal and paint the back side of welded area when finished.
Re: fuel door
Thanks everyone for responding to my question. Keep the information coming, it will not be wasted.
John
