Anyone here familiar with these ? .
We have a 4.12 ratio one now and would like to up grade . Truck is a special order crew cab, long bed 3/4 ton chassis with a really high GVW as it was originally a sprinkler service truck for the highway department . It's a V8 auto matic we'd just like to ease up on the fuel guzzling a little bit . Thoughts ? . TIA,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Re: Dana 60 Axles ?
I did not think you could get a 4x4 crew cab as a k20 only a k30. Either way, what is the engine and transmission combo? Also single or duel rear wheels?
AJC Last edited by AJC; 09-22-2019 at 08:03 PM. |
Re: Dana 60 Axles ?
4.12 ratio ? ? ?
better re-check that . should be 3.73 / 4.10 / 4.56 more info on the truck like year / make / model / 2wd or 4wd / all this stuff . and if i recall 3/4 ton in crew cab was only 2wd . and crew cab was same frame as a C or K version so the frame is 1ton spec . and if its a square body crew cab its a 14ff if srw or narrow c&c axle drw or if wide drw its a dana 70 HD rear .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
THANK YOU guys ! .
It's a 2WD unit . Not actually a GM product, a 1979 Dodge we're the second owner of . We travel all over America in this old beat up but sturdy rig . Single rear wheels . 8,200 # GVW IIRC . I'll go check the ratio tag this week I hope . What I'm hoping for is junkyard swapping info ~ I'm here in California where I should be able to find a good used drum to drum rear end cheaply once I know what to look for . Thanks for taking the time to teach me .
Re: Dana 60 Axles ?
Didn't the dodges have dana 70 in the rear of 3/4 ton and up trucks? The first gen cummins had a 3.07 or 3.54 ratios offered, might be worth looking into those. Also a set of gears might end up costing the same as a junkyard rear end?
AJC |
Collector of Projects
Re: Dana 60 Axles ?
Find a late model AAM 14B full float disc brake rear end with the gear ratio you want from a local salvage yard. New spring perches and shock mounts will net you 4 wheel disc brakes ...
THANX AGAIN for all the ideas .
I'll go check to ensure the axle is a 60 series, the FSM said it's a Dana 60 IIRC . We don't want a huge project (I don't weld), the current brakes have never been unsatisfactory even when crossing the Rockies fully loaded so rear discs are not necessary .
