12-03-2003, 10:36 AM | #1 |
Stylin
th350c to th350 conversion
ok i read threw my th350 book and it shows a conversion kit to convert a lockup style 350 to a non lockup style. is there any visible difference between a lockup style converter and a non lockup style?
thanks Paul i also posted on the engine&drivetrain board, just thought id post here also since everybody questioned my retardedness when i mention a th350c lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
12-03-2003, 10:44 AM | #2 |
Slots go on anything!
I think there is another set of splines on the output shaft of the trans, like on a 700R4. If so, I would guess there should be a corresponding set inside the converter? I have never had a 350C out to know 100%, but I know it to be true on a lockup 700. Hope this halps a little.
1974 Jimmy- 5.3/4L80e/NP241 |
12-03-2003, 11:00 AM | #3 |
Stylin
well the kit in the book listed the front pump, new spline, n other parts needed to be able to go regular th350 but not change the rest of the trans. im just wondering if the lockup tc's are larger in diameter than a regular tc
12-03-2003, 12:24 PM | #4 |
FWIW, you might be better off just getting an older TH350, as the cost of the pump and input shaft would probably be around the same as getting an exchange rebuilt one. They usually go about $250-300 exchange here in Dallas, I would bet it is probably close to that in OKC. If your trans is working OK, it would make a good exchange unit.
12-03-2003, 12:39 PM | #5 |
Insert Witty Text Here
Why convert? If you don't like the lockup, just disconnect it or put it on a switch.
If your transmission is bad, then just ignore this post. Slonaker |
12-03-2003, 02:09 PM | #6 |
The non lockup t/c is smaller and lighter than the lockup but from what I understand from the guy who built mine is there are a couple other things to change including some drilling I would go with jonboy's idea and get another tranny. I just got mine here for 350 and it is sweet .
Steve |
12-05-2003, 02:15 AM | #7 |
Just unhook it. I bought my 79 Sub about 5 years ago with a bad trans & I replaced it with a rebuilt 350C, which works fine unhooked. If I remember correctly (and this is debatable), the 350C converter had a raised flat area on the front, as opposed to a regular 350 converter which did not.
12-05-2003, 10:35 AM | #8 |
the raised flat area at the front is the actual lockup clutch. A normal 350 TC will be round at the front and rear.
I don't know a whole lot about the 350C. I do know that if the lockup is not working on a 700, it will overheat. Will disconnecting the lockup on a 350C do the same thing? I have had it happen when the speedo cable broke on my el Camino, and it got hot enough that the engine temp was raised. It also set a check engine light, with a TCC fault code. That is why I would be hesiant about just disconnecting it. If your trans is fine, it would get you by for a while. A regular 350 converter might be the way to go there. If you are putting in a converter, you almost have the trans out. If it is the original trans, then you have at least 17 years of use on it. That is why I would suggest a 350 swap, and it is (relatively) cheap, if you do the labor yourself.
12-05-2003, 11:26 AM | #9 |
Stylin
Thank you jonboy your the only one thats answered my question. I only wanted to know about the tc, not everything else. my trans has been unhooked from the day i purchased it and its outlived a rebuilt 305. sry if i come off as an arsehole but tech support for my outgoing mail server has been nothing but SH*T. They have yet to answer my question of why i cant log on, 8 replys and they tell me how to set it up in each reply even tho i could log on just fine 2 weeks ago.
12-05-2003, 11:56 AM | #10 |
no prob, man. That's why we are all here.
