Old 10-15-2019, 04:06 PM   #1
WilliamFd55
His name is "George" 84' C10
I'm back!! Sold my previous truck from the build thread (New year, new body 70c10 to 86c10) and been itching for another one ever since. Found this Beauty on eBay and the previous owner laid out the perfect ground work for me to take it from here. Chassis was completely redone, every line, bushing and full airbag set up with 4 link. Here we go.......
WilliamFd55 is offline   Reply With Quote
Old 10-15-2019, 04:13 PM   #2
WilliamFd55
Re: His name is "George" 84' C10
First modification in the books as soon as it hit my driveway... Previous owner cut a hole in the side of the bed for the exhaust. I did a similar exhaust cut out on my 70' with a FD 4" Storz connection as the tip and I think it worked out pretty good here?
Old 02-12-2020, 12:07 PM   #3
moregrip
moregrip's Avatar
don't see many of those orange wheels chocks around; I have an "old" set that are still hanging in there
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 10-17-2019, 12:33 PM   #4
daddyjeep
daddyjeep's Avatar
That would be tough to let one go that was so nice. Hopefully you were compensated well for that. The new one looks like a solid start though.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-23-2019, 01:50 PM   #5
WilliamFd55
Haha, it was. I immediately regretted it and I was.....
Old 12-23-2019, 02:06 PM   #6
WilliamFd55
So I'm in the gathering stage and have a line on motor. Will post pics once I get it. Picked up some wheels and tires and if anyone seen my last build, you know it was budget friendly .
Here's the rundown:
American Racing Classic Torq Thrush 2 (VN215)
20x8 0mm offset 4.5" BS, With 255/45R20 Pirelli Scorpion Verde up front.
20x10 +6mm offset 5.75" BS, With 295/40R20 Pirelli Scorpion Verde rear.
Rims/ Tires/ Mount and Balance were under a G note.
Will have to trim a little of the inner bed to completely lay down in the rear.
Also scored a set of bumperettes, which were hard to find but I think they look awesome on this year.
Old 12-25-2019, 12:59 AM   #7
moregrip
moregrip's Avatar
Here's the rundown:
That looks fantastic
Old 12-24-2019, 01:31 AM   #8
franken
Nice.
A PSA:
'84 is 1984
84' is 84 feet
Old 12-24-2019, 10:18 AM   #9
WilliamFd55
Originally Posted by franken View Post
Nice.
A PSA:
'84 is 1984
84' is 84 feet
Get the red pen and stick around, THEIRS plenty of corrections to come . Damn NJ school system........
Old 12-25-2019, 10:30 AM   #10
LT7A
Hahaha, well played. I appreciate good spelling, grammar, and punctuation but realize that not everybody cares about that. I'd rather not miss out on the story which is what I think would happen if all that stuff was made a priority.
But I do have sympathy for a guy if he clicked on this thread thinking he would see a C10 that is 4 times the typical size, haha.
Old 01-02-2020, 02:52 PM   #11
WilliamFd55
Checked one major item off the list.
Had good communication with the seller of a 5.3 and was able to strike a deal. Funny thing, the motor was only 15 mins. away from where I purchased the truck (3 hours from me).
2002 LM7 5.3 LS
Here is what was done and some goodies it has:
3 Angle valve job
Bores honed
Mahle piston rings
Gaskets/ seals (full set)
Melling replacement oil pump
GMPP ZR1 cam
Cam bearings
PAC 1218 Valve springs + valve seats
Speedmaster head studs
BR7EF plugs
The plan is to find a NV3500 trans that will bolt right up and will have a hydraulic throw out bearing this way, I don't have to mess with linkage. I know there has been some long debates about this trans. It comes from the factory mated to 4.8's and 5.3's, so its good for me. Don't plan on slapping a number on the door and racing this, plus who has money for a T56 anyway?
Old 01-07-2020, 05:15 PM   #12
WilliamFd55
Leave it up to me to get sidetracked....
Picked up a toolbox like I had in my other truck and plan on moving the air compressor, maybe the tank? and the battery in there. The battery is currently mounted to the frame rail under the bed in front of the passenger rear wheel. I found an old breaker box that will work well, once modified to protect it and looks pretty cool too. Here is some progress pics.
Old 01-07-2020, 06:24 PM   #13
rodstored-72
chevy truck fan
rodstored-72's Avatar
Very cool build. I am not one for the "slammed to da ground" look, but with the wheels it looks nice. I love the bed treatment & the breaker box idea!!
rodstored-72 is online now   Reply With Quote
Old 01-08-2020, 01:40 PM   #14
daddyjeep
daddyjeep's Avatar
That is certainly a cool battery box. Nicely done.
04 1500 crew cab
Old 02-10-2020, 01:17 PM   #15
WilliamFd55
Finally finished the battery move. Came to the realization that it must have been mounted to the frame before the bed was installed, because it was impossible to get it out! After a little modification, I was able to reuse the existing battery box by bolting it inside the new one.
Old 02-12-2020, 11:50 AM   #16
Low Elco
That's tight!
Low Elco is offline   Reply With Quote
Old 02-13-2020, 02:05 PM   #17
tintbox
Looking good!
tintbox is offline   Reply With Quote
Old 02-21-2020, 09:00 PM   #18
SCOTI
SCOTI's Avatar
I'm liking the battery box. My 64 had a smallish sheet metal toolbox mounted in its bed. It had some old Gates belts, tire iron, a few bolts/screws, & a bunch of dirt . I thought of doing something similar & using it as my battery box since the 'patina' matches the inside of the bed perfectly. But, it's not tall enough which would require tweaking the bed wood to suit the needs…. Still undecided on mine but I like your set-up. I even used/had the same tool box for my dually before raising the bed floor. It's now used for parts storage in my shop office (it's like a coffee table in front of the futon)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-24-2020, 01:02 PM   #19
WilliamFd55
Thanks guys. Its always fun doing something different and upcycling is budget friendly .
Old 02-24-2020, 01:16 PM   #20
WilliamFd55
Busy and productive weekend. Was able to finally modify the inner fender wheel wells to allow those 295's to not hit when fully aired out. Used thin sheet metal and pop rivets and was able to bang it out in one day. Lost (2) mounting screws on each side, but still have about 5/8" clearance and retain the stock tubs. The undercoating covers everything up and as long as the water can't get in there, I'm happy.
Old 02-26-2020, 10:46 AM   #21
WilliamFd55
Started some work on a radiator overflow. I've collected some cool bottles over time and figured this would work perfectly, since the trucks name is George
Dusted off the ring roller and used a water jet cut star I got off of eBay as the base. Still learning the ins and outs of Tig, so will probably Bondo to clean it up and paint.
Old 02-26-2020, 10:51 AM   #22
rodstored-72
chevy truck fan
Nice.....
Old 02-26-2020, 01:23 PM   #23
erichevy
erichevy's Avatar
Great progress so far. I'll follow along
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 02-28-2020, 10:27 AM   #24
Rich84
Rich84's Avatar
Did that have whiskey in it??
I love all things George Washington.
Rich84 is offline   Reply With Quote
Old 03-02-2020, 12:44 PM   #25
WilliamFd55
Did some digging "Google ". Found that it was a bottle of Chianti wine for the Bicentennial.
