10-17-2019, 02:00 PM | #1 |
1968 Chev K10 Carb.
I have a 1968 Chev K10 3 door Suburban that came with a 307 but has a 350 in it now. I have owned this Suburban since 1970. It has a Rochester Quadrajet 4 Brl. carb. on it - 7042208 OC 1172 which was on the engine when it was installed years ago by a mechanic I bought it from when mine had problems. It has a 4 speed manual transmission, manual steering and manual brakes. I need a different carb as I have to pump and pump to get it started. Had a new manual fuel pump installed and a carb kit put in but after it sits a few hours it will not start without pumping,I installed a one way valve in the gas line at the carb so the gas would not drain back but did not help. What would be a good alternative?
Jas |
10-17-2019, 02:27 PM | #2 | |
The Older Generation
Re: 1968 Chev K10 Carb.
Are you sure the choke is working correctly and are you setting the choke each time before you try to start it? LockDoc
10-17-2019, 03:07 PM | #3 | |
Jas |
10-17-2019, 03:51 PM | #4 |
From way over here it sounds as if your accelerator pump in the carburetor has failed. A common problem with the fuels we get to use these days. Do you have a stumble when accelerating?
A quick check would be to look down the primary bores of the carburetor (a flashlight will help) and wing the throttle open. You should see two solid streams of fuel shoot into the carburetor bores. You will need to hold the choke open to do this and you do not need to have the engine running to do this.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-17-2019, 05:25 PM | #5 | |
Thanks, JAS |
10-17-2019, 07:19 PM | #6 |
I suspect that you are on the right track. I believe there are wells in the bottom of the fuel bowl that are sealed with solder. Over time the solder dries/loosens/cracks allowing the fuel to drain down into the intake manifold, creating the conditions you describe. It can be repaired.
10-17-2019, 07:54 PM | #7 |
The fact that the truck runs but no accelerator pump shot to me means that the either the accelerator pump seal has failed or the check valve for the accelerator pump is stuck.
My money would be on the pump seal failing. It is quite possible that the seal's lip stuck to the pump bore when the fuel evaporated and then when the pump was operated it tore the lip and now it won't seal. Or the seal is stuck to the bore and the whole cup has pulled off of the accelerator pump shaft. This link may help explain what I believe your problem is. http://www.v8buick.com/index.php?thr...-issue.263146/
10-17-2019, 07:57 PM | #8 | |
Even though it is an automatic choke you still have to set it before you start the engine. Here is how the owners manual says to do it. If it is an electric choke you have to have the key on for a couple of seconds before setting the choke. Owners manual says: "Fully depress accelerator pedal and slowly release. With foot off of the accelerator pedal crank the engine by turning the key to the start position and release when the engine starts. If the engine starts but fails to run, repeat the above procedure. When the engine is running smoothly the idle speed may be reduced by slightly depressing the accelerator pedal and then slowly releasing." On another note, It would be a good idea to have the air cleaner off the first time you do this to see if the choke plate is actually closing. If the engine is cold the choke plate should be fully closed after setting it according to the manual. LockDoc
10-17-2019, 08:55 PM | #9 | |
