Old 10-18-2019, 11:07 PM   #1
CS1972
CS1972's Avatar
Installation / Mounting instructions for 1972 DG4 mirrors
Does anyone have a better picture / pdf of the mounting instructions for the 72 DG4 mirrors? And.............what manual are these instructions in?
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 10-19-2019, 09:59 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Installation / Mounting instructions for 1972 DG4 mirrors
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-18-2020, 07:57 PM   #3
bry593
Anyone have a clearer picture of the mounting instructions? I'm having difficulty reading the dimensions for the DG4 location.
Thank you!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 07-18-2020, 11:43 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Thank you!
I looked in the Factory Assembly Manual but didn't see anything about the DG4's. The illustration you posted must have come from the Chassis Service Manual and the only one of those I have in the house is for '67.
LockDoc
Leon
Old 07-19-2020, 03:04 AM   #5
Richard
Never seen that page, not in the service or assembly manual. Can measure mine as it had original DG4 type mirrors.
Richard
Richard is online now   Reply With Quote
Old 07-19-2020, 09:42 AM   #6
bry593
Thanks Richard. Need the dimensions as shown from door leading edge to top and bottom mounting holes.
I think the screws are 1/4-14 SS sheet metal screws to fit 3/16 drilled holes. At least that is what I am seeing in the picture.
Old 07-20-2020, 04:52 PM   #7
LockDoc
LockDoc's Avatar
I bumped this thread back to the top today. It suggests a couple of different measurements.
http://67-72chevytrucks.com/vboard/s...d.php?t=800535
LockDoc
Leon
Old 07-21-2020, 02:05 AM   #8
Richard
The thread Lockdoc pointed out has good info. Did not visit my truck until today. My truck orginally had the painted DG4 (D29) The holes are small because they were welded up in drivers door and re-drilled before paint. I will be installing the rivit nuts pointed out in the other thread. Holes were still in my old passenger skin I kept. I verified driver and passenger mirror locations are the same.
Richard
Old 07-21-2020, 12:43 PM   #9
bry593
Thanks Richard. Danny also sent some pics. I uploaded to the gallery, but can't seem to post pics directly to this thread. So here are the links:
https://67-72chevytrucks.com/gallery...hp?photo=46861
https://67-72chevytrucks.com/gallery...hp?photo=46862
Based on your pics and comparing to what I can sort of read from the OE instructions, I'd venture this is the original intent:
*Drill (3) 0.19" (3/16) holes thru
*Top hole is 8.25" (8-1/4) back from leading edge of door.
*Bottom forward hole is 5.81" (5-13/16) back from leading edge and down about 6.13" (6-1/8) from body line.
*Fasten to door with (3) #14-14 x 3/4, stainless steel hex washer head or Philips pan head screws.
I plan to seal the screw holes by placing a small blob of butyl rubber on each hole and putting the screw thru the center of it. This is the same butyl "ribbon" used to seal front and rear windshields in 1970's GM cars. Should work fine.
Old 07-21-2020, 01:06 PM   #10
bry593
The OE elbows are chrome plated steel and are usually pitted. LockDoc shared a thread with some possible aftermarket alternatives for both elbows and mirrors:
Elbows, 4.5” even offset
Signal Stat 7933
Truck lite 97869
Napa LIT 97869
Mirrors
Truck lite 97805
Signal Stat 7053
Other part numbers
97842
97681
By the way, all of the hardware can be found at http://www.boltdepot.com, and costs about $25 shipped.
Needed to rebuild one pair of mirrors:
*(8) Nylon Washers - .406 x .94 x .06
*(10) SS Plain Washers - .406 x .88 x .06 (Varies depending on washer thickness and stud length)
*(4) SS Lockwashers - .406 split
*(4) SS Acorn Nuts - 3/8-16 UNC
*(6) SS Washer Head Screws - #14-14 x 3/4 with .515 washer
*(6) SS Internal Tooth Lockwashers - .281 ID (if you want to use under attachment screws, but probably not necessary)
