Roadtrip!
![]() Join Date: Feb 2003
6 cyl power steering ID?
Scored a bunch of parts this week and among them are what is supposed to be 292 power steering set up and a 250 steering setup. The 292 was pulled from a 69 and the 250 was an early 70s I was told. Can anyone confirm or deny? I don't do a lot with 6 cyl stuff...
Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
Re: 6 cyl power steering ID?
Anyone ID the pumps and brackets?
The banjo shaped is for our years of trucks and cars.You'd have to match the main bracket to the right head for the exact fit.
The tear shaped is for later 70's and up.Looks a lot like the one on my 78,C-10. Best I can do without trying to fit them to an engine. Mike. ![]() |
#4 | |
Roadtrip!
![]() Join Date: Oct 2015
The bracket that attaches to the motor I believe is correct for 69-72 292's. That being said everything else seems to be different. That bracket is suppose to mount directly to the pump, where yours has another bracket in between the two. The pulley is different than original and so are the adjusting rods. If you took it off from a complete engine, must be everything lined up though.
The Older Generation
Here is what I have saved for 292 PS bracket pictures. The problem is every time someone posts pictures of the brackets there is something different on them. LockDoc
I understand what your saying, over the years things get changed around. Too much stuff I believe has an original bracket, but it's missing the extra piece in the first picture. That is what holds the back of the pump to the bracket. His has another piece in between that is holding it. Could you by any chance get me a number from the pulley on the last pump you have pictured there, I would appreciate it. I need a pulley for one. I need one like this one.
#8 | |
LockDoc
Roadtrip!
Thanks for all the input guys. So it looks like I have a correct 292 set up and a 250 setup. Any idea on values? I only have what is pictured, no other pullies or anything.
