Old 10-24-2019, 12:42 AM   #1
69GMC2004
Active Member
X pipe or no X pipe
Hey all, I'm wondering if anyone is running an x pipe exhaust set up on their trucks? I have a trailing arm set up and would like to keep the exhaust between the frame rails. If anyone is successfully running something like this some pictures of your set up would be fantastic.
69GMC2004 is offline   Reply With Quote
Old 10-24-2019, 11:58 AM   #2
weq92f
weq92f's Avatar
Re: X pipe or no X pipe
I had the exhaust shop add in an H pipe just south of the collectors. This mellowed the sound quite a bit...made it sound a bit more tame...smoother somehow.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-24-2019, 01:42 PM   #3
69GMC2004
Active Member
Hth,
-klb
Thanks. I think an H pipe could be worked In pretty easily, but I’m curious about x pipes specifically.
Old 10-24-2019, 01:46 PM   #4
MySons68C20
MySons68C20's Avatar
X pipes are tough to add especially if you are trying to keep the exhaust tucked up. I went with an H-pipe as well and it sounds great.
What is your reason for wanting the X-pipe, sound or performance?
MySons68C20 is offline   Reply With Quote
Old 10-24-2019, 02:58 PM   #5
69GMC2004
Active Member
Thanks for the reply. Reason for the x pipe is sound, I realize that there is virtually zero difference performance wise between an h pipe or x pipe (at least in most applications anyway).
Old 10-24-2019, 04:08 PM   #6
68 P.O.S.
Magnaflow makes a complete exhaust system with an x-pipe for these trucks. You can at least look it up to help determine where you want to place yours at.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-24-2019, 04:32 PM   #7
notsolo
notsolo's Avatar
I took the magnaflow 2.5 X pipe off....To much drone.
notsolo is offline   Reply With Quote
Old 10-25-2019, 06:56 PM   #8
69GMC2004
Active Member
Where did you have the x pipe mounted?
Old 10-24-2019, 06:33 PM   #9
68Gold/white
I've read of folks that installed the "X" pipes, for whatever reason. Took them off install "H" pipe, made exhaust easier on ears...
68Gold/white is offline   Reply With Quote
Old 10-24-2019, 07:32 PM   #10
57larry
no X pipe, just straight pipes with mufflers
57larry is offline   Reply With Quote
Old 10-25-2019, 12:47 AM   #11
whtgmc68
whtgmc68's Avatar
I have an H-pipe on the 2.5" exhaust with Spintech 6000 series mufflers on my GMC and it sounds amazing! I added the H-pipe when I replaced the Magnaflow mufflers I had because it was too quiet on a truck with a healthy 383. Now it is basically perfect, aggressive at idle and WOT, but mild at 2,000 RPM cruise with no drone.
Now, on my LS3 powered 67 Tempest, I went with a full 3" exhaust with the same series 6000 Spintech mufflers and an X-pipe and dear Lord is it a whole other story! It is insanely loud and has a terrible drone from 1,200 to 1,900 RPM, but smooths out to a tolerable level at an 80 MPH cruise at 2,500 RPM. Just don't try to drive around in 6th gear at 55, it will blur your vision!
I realize there are a lot of different variables between the two vehicles but an X-pipe can make an exhaust louder and maybe even raspier.
whtgmc68 is offline   Reply With Quote
