11-04-2019, 08:00 PM | #1 |
Wheel studs
Like many on this site , I need longer wheel studs.
My K1500 has. 7/16 x 20 but I am not sure about the spline size . I am guessing .560 but not sure. I don’t want to drill out for larger studs but will if I have to . |
11-04-2019, 11:23 PM | #2 |
Currently Blazerless
Re: Wheel studs
Are you wanting to go longer or bigger? I changed out 7/16" to 1/2" one time without any redrilling, wish I would have hung on to the part numbers. If just going longer you should be able to get them from about any good parts store. Take an old stud with you and hopefully theyll let you look thru their Dorman cacalog.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
11-12-2019, 10:23 AM | #3 |
Re: Wheel studs
I went through the same thing on my 72 k10 with after market rims and tires. I needed a longer stud to have more threads/stud sticking out of the rim but there's not much out there on the market. I did find a dorman stud that was the correct size but the shank ended up being a little longer than needed so the lug nut wouldn't tighten down and I really didn't think the quality of the stud was very good and didn't want to trust it with a 35x12.50-18 tires. I ended up putting my stock studs back in and buying new lug nuts with a longer neck that goes further in the rim and catches about 3/16 more threads.
11-12-2019, 11:44 AM | #4 | |
Re: Wheel studs
11-21-2019, 12:13 AM | #5 |
Re: Wheel studs
Dorman made a 1/2 stud that would fit the Dana 44 at one time but it was discontinued. I’ve heard there are ones that fit but I don’t know the part number. 12 bolt is the easy swap. I would like to swap out to the 1/2” myself but wish I could find what fits. I would be willing to drill the hub if needed. If you go through the work to remove the hub I would try to get 1/2 studs since you’re in there. It’s a little work to reset the preload and everything when doing the job. It’s also good measure to just go ahead and replace the bearings and races if it’s original. They are cheap and not hard to do.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
11-21-2019, 12:19 AM | #6 | |
Re: Wheel studs
11-23-2019, 01:07 AM | #7 |
Re: Wheel studs
I may have to call and see what they say. I have aluminum wheels so a longer shank shouldn’t make a big difference.
12-25-2019, 08:02 AM | #8 |
Collector of Projects
Re: Wheel studs
