![]() Join Date: Dec 2014
292 Thermostat Housing Help
So I am the proud owner of a 68 c20... build thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=795837 And I am also therefore the proud owner of a 292 which I know nothing about. This one has a lot of - I suspect - 250 and other eras of inline 6 parts on it - and one of the issues I am facing is the fact that it seems to have the wrong thermostat housing on it: specifically the lower part which bolts to the head. I discovered this when I ordered a new water pump and upper rad hose and it went together like Ray Charles assembled it with his feet. Can someone please send me pics or part numbers of an original thermostat 2 piece housing with the bypass? Specifically the lower part which bolts to the head. I have the below pic I found on another site which somewhat resembles what I think it would look like. I am pretty close to getting this junk on the road, please give me anything you can in terms of info.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
![]() Join Date: Dec 2013
Re: 292 Thermostat Housing Help
From left to right
late 292 -- 67 292 -- 67 250 . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
292 housing
Would you please send me a closer pic of the middle engine, the 67 250? Mine needs that fitting on the left side of the lower housing. I appreciate your help.
What exactly would you call that housing under the thermostat housing... the one that bolts to the head? Trying to search for this part and coming up with nothing.
Did you order the same water pump as you removed? The 292 used the style you have pictured from 63-67. In 67-73 they changed the water pump and the thermostat housing and it takes a bigger bypass hose. This is a picture of my 69.
Grumpy thanks for sharing the information along with everyone else. I was wondering if you happened to have a source and part number for the bypass and lower radiator hoses? I seen to keep ordering parts that don’t quite fit.
Thanks again Dongray Posted via Mobile Device |
The early 292 engines used a 1 in. bypass hose like Grumpys photo. The later 292's, about 1970 up used the 5/8 bypass hose like in the photo in Dags post.
George |
![]() Join Date: Jul 2016
a while back there was a seller(12bolt_tom) on ebay that had both iron and alum. new upper and lower thermostat housings. i think he had the style you want, i almost bought one for my 292.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
Check this ebay ad.
![]() Better hurry there are a lot of guys looking for the same parts . https://www.ebay.com/i/193151428763?...BoCA1cQAvD_BwE https://www.ebay.com/i/192955469159?...xoCMzQQAvD_BwE
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 11-08-2019 at 10:24 PM. |
Thanks for all the info, I appreciate it! I never would have thought that this part would be so difficult to find, I just assumed I could order it off the shelf.
Also, turns out that Tom has a website, https://www.12bolt.com/ I will reach out.
![]() Join Date: Nov 2006
Bigger is better if your gonna work / towe with it
I BELIEVE IN JOHN 3:16 |
Thanks for all the advice and info!
I found the below item on ebay. Now that I know that these are rare and apparently valuable I will be on the lookout for them at every junkyard I go to.
#14 | |
#15 |
I several oil bath air cleaners, people actually want these things?
#16 | |
#17 |
![]() Join Date: Feb 2002
Grumpy, don't forget the 292-only [K-Type] 4WD diagonal crossmember.
#18 | |
#19 |
Think I have pix somewhere...
#20 |
HI, just for the sake of closure and to thank everyone who gave me advice on this subject, here are some pics! The part I bought off ebay cleaned up well and fit nicely, and now the truck purrs like a kitten, bypass hose and all.
In the summer I hope to get in there and detail everything and paint it to look as nice as grumpy's.
#21 |
That dist is 1975 only, so if you find one, take everything. The side cover bolts for the coil are special. The Dist housing is indexed differently for the ex/coil cap than the coil-in cap housing. The module-to-coil wiring harness is different than the coil-in-cap inline HEI.
I see old51sedan has an HEI with a shaft with the flex joint. That shaft was discussed on this forum years ago and there were different opinions about where it came from. I have a 6cyl HEI with that shaft, but don't want to use it. The one in my engine has the solid one-piece shaft. The cover over the coil plug is the only one I have ever seen and part is missing and the rest is as much epoxy as plastic.
'67 GMC 2500, 292, 4spd, AC |
