Old 11-07-2019, 03:19 PM   #1
msg
Brake and other line replacements on a 66- what to get?
Im nearing the point where the lines can go back in and I plan to replace what came off. Ive never done this before so I dont want to screw up and order stuff that doesnt fit or even things I didnt need. Is it best to buy pre bent or bend it up for a newbie? Ive got a tool for the bending I used in the past and I think I could manage the bending..the flaring and hardware parts I have no idea about though. Here is what I have in the pile of replacement parts. I only labeled the transmission cooler lines so Ill need to make sure I have the lines properly identified. In this pic, I think these are all brake lines, but the one to the left has a double line thing going. I have a dual master cylinder but the kits Im finding online on a 66 dont have that, so where should I be looking instead since a conversion had been done before?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 11-07-2019, 03:22 PM   #2
msg
Re: Brake and other line replacements on a 66- what to get?
More brake lines
Old 11-07-2019, 03:24 PM   #3
msg
Trans cooler lines
Old 11-07-2019, 03:26 PM   #4
msg
Even the parking brake cables I need to reorder and this is what I had removed before.
Old 11-07-2019, 03:51 PM   #5
vince1
Assuming drums all around and single M/C I'd at least change it to dual chamber M/C. Get one from a 67, and from what I understand front line goes to front brakes. Buy a flaring tool and have fun. You will of course need to get some fittings to split the front and back.
If you plan on keeping your original M/C I wouldn't even bother renewing the lines, unless they have rust pitting.
vince1 is offline   Reply With Quote
Old 11-07-2019, 04:18 PM   #6
msg
Thanks Vince, yep ive got a dual MC and definitely will be replacing lines. I guess the pre bents are not worth even if I could identify a match for what I need. Im concerned about buying a pre bent and not getting the right fit/or part. Also the cost. I would guess its cheaper to handle it yourself with stainless steel.
Old 11-07-2019, 06:27 PM   #7
jayoldschool
Moderator
I wouldn't do stainless, do the cunifer lines, they bend super easily (and flare great). That's what I used on mine when I re-did all lines for my dual master.
jayoldschool is offline   Reply With Quote
Old 11-07-2019, 06:46 PM   #8
jayoldschool
Moderator
duplicate
grr rural internet, lol
Old 11-07-2019, 07:11 PM   #9
msg
Thanks Jay, is 3/16 the standard? I did a search for cunifer lines and saw this
https://www.amazon.com/Brake-Line-Un...27330710&psc=1
I also watched this guys video on how to, seems do able!
https://www.youtube.com/watch?v=9V9Jg1BORlk
Old 11-08-2019, 12:43 PM   #10
roll_the_dice
roll_the_dice's Avatar
Most people run 3/16" line...it is easier to bend and form for the most part. I am about to redo some of my brake lines and bought this forming/bending tool from Eastwood. Can do multiple size lines so is good for either or other projects. I already used it to reposition a steel line for my power steering hard line. It worked great.
roll_the_dice is offline   Reply With Quote
Old 11-10-2019, 11:13 AM   #11
diver
if you go with inline tub make sure you tell them on master cyl. 1 or 2 line and were you want union on frame stock is in back just did 1 last week and they sent wrong piping for 1966. k-10...have 66 c10 owned for 50 years same brake lines..if you lived in dallas area i have stock 66 to look at for info.
diver is offline   Reply With Quote
Old 11-07-2019, 11:35 PM   #12
cwcarpenter98
cwcarpenter98's Avatar
First pic with the two lines attached together: The line with the rubber hose on each end is the fuel line from the tank to the fuel pump. The other line is the single line that runs back to the rear brakes
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-07-2019, 11:57 PM   #13
msg
Thanks Christian for helping me sort this all out. Is there a standard size for fuel, brake, and trans? Is 3/16 good for all?
Old 11-08-2019, 07:52 AM   #14
PGSigns
PGSigns's Avatar
Look at inline tube for a lot of what you need. The have most of it. Depending on what brake upgrades you have done you can use parts from other years. If you are still on all drums a kit for a 67 will get you what you need. For the fuel line you need at least 5/16. I ran 3/8 on mine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
