Old 11-11-2019, 12:58 PM   #1
Danman09
6 cyl 3 on the tree shift rod question
Does anyone know where I can buy new bushings and grommets for the shift control rods ? Maybe a part number that would replace them ?
Danman09 is offline   Reply With Quote
Old 11-11-2019, 10:40 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 6 cyl 3 on the tree shift rod question
Here's thread you need to read. It has some sources for the parts in the comments.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-12-2019, 12:16 AM   #3
Grumpy old man
Grumpy old man's Avatar
This should help .
https://www.classicparts.com/1947-76...info/91%2D062/
Old 11-12-2019, 12:19 AM   #4
Grumpy old man
Old 11-12-2019, 12:51 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 6 cyl 3 on the tree shift rod question
I found this for you in another thread but should be good to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=505012
https://www.classicparts.com/1960-76...ctinfo/91-063/
https://www.classicparts.com/1947-76...ctinfo/91-062/
https://www.classicparts.com/1960-72.../#.U7wTW41dW2N
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2019, 08:01 PM   #6
67GMCcampercruiser
Lots of good info here. Hope to find this when I need it.
67GMCcampercruiser is offline   Reply With Quote
shift rods
