My Frustration Level High
This 68 GMC k1500 truck is going drive me insane ! This being a one of a kind year makes it almost impossible to complete anything with out something else cropping up .
Could not find the longer 7/16 wheel studs with .56 spline , so had to go with a set of 1/2” x 20 x.56 spline. Everything worked out except now the brake drums have to be re drilled because the stud holes are to small. Why because in order the get a longer studs I also had to settle for a longer spline which interferes with the brake drum stud holes. Try getting a new set of original style springs for this thing , not going to happen . Eaton made me a set but nothing like the originals . The drive shaft is another never thing , no one ever saw this stinking pencil style drive shaft . So had to have one made , power steering ? That was fun ! Now my newest project , power assist brakes and I can see problems coming already . I have 7 months left to get this thing on the road for a cruise to N.Y this spring. At this rate I’ll be every day for the 7 months getting it road worthy. They only made about 500 of these things and I think I have one of maybe A half dozen left in the country. In fact they made so few of them , an old GMC sales person swore they never made my truck . When he saw it , he still wondered were he was when it was being sold. Ok , that’s my rant . Back to the garage to work out another issue ! |
![]() Join Date: Feb 2016
Re: My Frustration Level High
Okay. Deep breath now. And take comfort in that your not working on something obscure like an Avanti, a Checker or an International, whom the counter person at the parts store has never even heard of.
And everyday the list of things to do gets smaller and the list of things you can be proud overcoming of gets longer. Good work!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#3 | |
I'm glad to hear that. I can relate to your feelings, I have a 70 Javelin.
![]() Join Date: Apr 2016
Sorry to hear about that, but thanks for sharing. It took me a long time to get mine road-worthy. Some of the time was spent on buying stuff that was not really well suited to the truck and then I had to do it again. So everything took twice as long while I learned my lessons. Nowadays I spend tons of time researching stuff to make sure I'm getting good stock-like parts, and buying stuff here from you guys in the parts section of the forum when I need something obscure that I can't just find locally or if I can't buy of sufficient quality from the catalog/online companies. I'm becoming a fan of good used parts. I don't settle for something that just works, because in my experience it often only works for 5 minutes and then craps out if I go cheap or go with what's readily available. I am able to work on comfort items and options more now, and managing to keep up with essential mechanical and electrical stuff that breaks down only occasionally. It is exhausting, but it's coming together. It sounds like your truck was heavily modified before; I can understand it would be difficult putting things back to "normal".
#6 | |
Any how it’s a heck of a learning experience . |
#7 | |
#8 | |
#9 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 11-12-2019 at 09:46 PM. |
I didn't know if I wanted to step into this one or not! I have a question. How much did you know about a '68 K1500 when you decided to go about this restoration? Ok. Well, you're learnin'
![]() The spring width on 4wds changed to narrower after '68. '69 has the same drivetrain and was last year for V6. Steering changed in '70 as well as new transmissions and transfer case came out. Basically, drivetrain changed except rear. Then disc brakes on same front end in '71. A lot of people go with swapping to later components for convenience, parts availability, serviceability, upgrading. Restoring to original is never the easiest route. You take a direction and keep going until it's done. Maybe move to another thing when something gets frustrating. You'll get it done.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-13-2019 at 10:40 AM. |
#11 | |
Old member
![]() Quote:
I got some better pictures of them than before! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
I am not *****ing about this , just frustrated , mostly because no one has many answers for this truck. When I called Dorman about longer wheel studs , he chuckled when I told him it was a 68 K1500. Then he helped me with what he could. I already restored a 69 Mustang Mach 1 , a peace of cake compared to this. This truck wasn’t supposed to be like a stutz bear cat , or a Cord just a regular 4x4 truck. |
#13 | |
#14 | |
Have you ever owned one or worked on one ? From you answers most likely not . |
#15 |
I might know a little. I'm guessing you haven't read too many of my answers. With a better attitude from you, I believe between me and my buddies here we could answer any question you have on that truck. After all, you did manage to stumble onto the single best resource for information on these trucks in the world. Time to stop whining and take advantage of that, you can save yourself a lot of grief and make a lot of friends in the process.
#16 | |||
"I ain't nobody, dork."
![]() Tim has forgot more about these trucks than most of us will ever know. Lighten up Francis... Your truck might be "rare", but it is still a 67-72 truck, and you're not experiencing anything that can't be done with some fab work or networking. Gary
#17 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I'm going to to stay out of this. But you have a ton of knowledge here. All you need to do is ask. There's also parts available too. I hope your frustration subsides. Have a great day.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#18 |
I have a 68 GMC K1500 and I was unaware that it was rare at all other than being 4wd. I bought it when I lived in CA and the original front differential was long gone and the transfer case had been replaced with a NP205. I have since changed the complete drivetrain as I wanted a heavy axled driver with an OD manual transmission.
I might have gone a different route, if I had known they were so hard to come by! |
#19 |
I find it hard to believe that any drive shaft that will handle the V6 is not enough for your V8.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#20 |
#21 |
10/30/19
Oh no
#22 |
![]() Join Date: Jul 2015
Im sure ARP would of had a solution to your wheel stud issue, if not they could of made you one.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#23 | |
Old member
I just finished building my whole 68 Chevy rear end and put all new studs in them. O-Reilly's had them in stock. I got 1/2" longer studs also. The Boss wheels are deeper than stock rally wheels so I wanted plenty of threads.
![]() Quote:
#24 |
I bet he laughed because you said 1968. Tell me what length stud you needed.
I told you the facts on what is different between the Chevy and GMC in '68. Nothing that isn't different any other year. GMCs ran Dana rears and Chevys ran corporate. And, through '69 GMC offered the V6 that Chevy never did. What makes you think a Dorman employee would be an expert on this year and model truck? BTW, your figures on how many were made and how many are left (How do you know?) are way off. If you want to know the actual production numbers I'm sure there are dozens of members here who could give you the actual facts. But nobody knows how many are left running around. You are getting help here and you are fighting it. We have nothing to gain by offering misleading information or giving you a false impression. We are a network here. What info one guy can't find another guy might have and we are ready to share. If how things work here don't work for you I believe you will be the first one. Many a truck owner has come here lost and bewildered to walk away with the info they needed. I'd like to help you with any other issues you run into, if I can. You're not done yet, right?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-18-2019 at 08:31 AM. |
#25 | |
I never said I got wrong information , where did you get that idea. I also Have gotten much help . And as for wheel studs , when the Dorman rep , tells me what he can do but it’s not the proper studs . Do you know more than he does about there product ? You are reading more into what this thread started out as. I said I was frustrated about how difficult it was to get this truck done and I didn’t complain about this site or the help I have gotten. And from some of the answers I’m not alone in my endeavors . There is a difference between the 68 K1500 and 68: K10 . The research tells me GMC and Chevy did not use the same platforms for there trucks until around 1970: so how can they be the same . Yes many of the parts are but much is not . Tell me why in many of the resto parts books , the year 68 Chevy parts are available but the 68 GMC are not . Yet there indenical . Can’t be . |
