11-16-2019, 03:23 PM | #1 |
72 seat replacement
I have been searching for a 88-98 bench seat for my 72. So far unsuccessful. What I like about these seats is the sculptured foam to set seating position. I read somewhere that similar year suburban 2nd row seats work also w/o ability to adjust. Since both myself and 5'2" wife drive w/original seat same position, all the way back, this doesn't seem like an issue. Has anyone used the sub 2nd row in their truck? It would seem that seat would be easier to find in decent shape w/o the broken down outside foam that every bench seat found so far has had.
64 Chevy Suburban/Carryall 4x4 72 C10 Highlander LWB 34 Chevy 5 wdo Street Rod 64 Corvette Roadster w/AC 78 TransAm WS6 78 GMC Jimmy 2WD Slammed SOLD! |
11-17-2019, 02:38 PM | #2 |
Re: 72 seat replacement
The second row suburban seat will work how ever they are 60/40 split and mount a little different then the frount. I would instead look for a crew cab and take the rear seat out of that. Full bench and mounts the same as frount bench. That's what I did. They are usaly in good shape as well.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) Last edited by 71gmcC15; 11-17-2019 at 02:57 PM. |
11-17-2019, 05:00 PM | #3 |
Right now I have found 3 99 Suburban full width 2nd row benches, and a 2010 rear crew. The 2010 looks appealing because the seat back appears thin and in theory should yield a little more room. So far all I have seen are online pics that don't show anything about mounts. I have been to all local salvage and found nothing but bad foam on the 88-98 front benches. That has me looking for alternatives on facebook marketplace. It would help greatly, knowing which year alternatives would work out best. What year is in your pic? I'm not seeing any rear w/ armrest.
64 Chevy Suburban/Carryall 4x4 72 C10 Highlander LWB 34 Chevy 5 wdo Street Rod 64 Corvette Roadster w/AC 78 TransAm WS6 78 GMC Jimmy 2WD Slammed SOLD! Last edited by 1972 C10; 11-17-2019 at 05:10 PM. Reason: more info |
11-17-2019, 06:14 PM | #4 |
It's out of a 95 4 door pickup. 95-98 rear says are the same. 88-94 rear seats are a different style they looks just like the frount bench. Mounting is pritty straight foward. Center mark holes and drill. Add spacer. For rear holes. If you want to be able to move the seat. Other wise install seat slid all the way forward to get the seat brakets behind the hump on floor. It's hard to explain but when you do it you will see what I mean. There are also several theads on this same subject.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
