Old 11-16-2019, 09:22 PM   #1
skip99
skip99's Avatar
Instant center location
51 chevy truck, mustang ii , 2” drop spindles, triangulated four link, Been reading about instant center, anti squat line, center of gravity etc...question is, based on your previous experience, when installing the four link, lower bar is parallel with ground...what degree down (towards front) should the upper bar be to get an IC at or slightly below the squat line, or what has worked well for you? Not looking for a drag setup, more street and fun curve driving, think autocross.. i ran across an article i think art morrison engineer, suggested 6-7 degrees down..opinions?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 11-17-2019, 08:55 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Instant center location
It's hard to say what your truck will need...every one differs some....
On most street 4links, a parallel bar setup works good...
If you have the mount plates with multiple hole your limited by whatever the hole pattern will get you
If you've never read this it's some good info.....http://www.ronsuttonracetechnology.com
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-18-2019, 07:52 AM   #3
PGSigns
PGSigns's Avatar
Depends on lots of things. What the truck will want as far as instant center and what you can get with the kit that you have may not line up. Until you see what the weight split looks like the amount of power you have when done and the total weight of the truck it will be hard to determine. You can map the four link out on paper and look at all the available combinations to see what the kit has. We would do this on the drag cars and shift the front bracket up and down to see where it needed to go to get us the range we wanted and then weld the brackets in the car. Then the chart we made with the map we drew was used to tune the car when we were done. There are programs out there that will do the work for you.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-18-2019, 10:46 AM   #4
robnolimit
robnolimit's Avatar
With the lower bar level, you can set some general rules. A steeper angle on the top bar (down in front) will move the IC closer to the rear axle. A flatter angle (closer to ) but still down in front) will move the IC towards, or past, the front CL. * A flat ) angle top bar will be parallel with the lower bar and thus have NO weight transfer. - but is good for burnouts. Starting in the 5 to 7 degree range will get you somewhere close for these trucks.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 11-18-2019, 12:17 PM   #5
skip99
skip99's Avatar
Thanks, just wanted a little verification of what ive learned and came up with, thanks
Tami's 51 build
Old 11-20-2019, 05:01 PM   #7
mongocanfly
That's a good link John...one I hadn't seen before..although alot of this is the same info found elsewhere..got it saved with my others though...never can have to much..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-12-2020, 06:45 PM   #8
skip99
skip99's Avatar
Thanks for the help, heres what i ended up with....
Tami's 51 build
