1971 Chevy turn signal harness problem
I bought the american wire kit for my old girl. Love it was easy everything works great. The turn signal mechanism in the steering wheel went. I bought a new one from LMC but the bulk head connector is curved and not flat like the original one that plugs right into the new american wire harness. The colors dont match up perfectly either so I dont want to splice them in yet. Any help out there?
Re: 1971 Chevy turn signal harness problem
Your description isn't very clear. (bulkhead connector???). If I understand what you are saying, your replacement switch harness doesn't plug into the main harness because the plugs don't match.. You need an adaptor harness to complete the connection..
Here's a link to the part you need.. https://www.classicindustries.com/pr...ts/cx1602.html The switch and it's accompanying harness is on the right, the adaptor is on the right.. Classic Industries, LMC, and others have that adaptor.. |
Thank you very much!!!!!!!!!!!!!!!
![]() Join Date: May 2003
I have the same adapter kit if you need one, new never used.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Figures I pulled the trigger before I read your response! Thanks a ton though!
#6 | |
Gary
