Old 11-23-2019, 06:52 PM   #1
Kaaso
Vintage air question.....
I am installing Vintage Air in a '66 C10 with factory air. What have you guys done to connect the Vintage air ducts to the factory center dash vents? I have purchased a couple of side vents for the sides but wasn't sure about the factory center vent.
Thanks in advance!
Kaaso is offline   Reply With Quote
Old 11-24-2019, 10:58 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Vintage air question.....
If you're referring to the different diameter sized hose ducts, several companies, including Vintage Air and Old Air, offer reducers, adapters, and Y connectors.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-24-2019, 12:29 PM   #3
spudder
Active Member
Do a search here for member nsb29. He has been making a duct assembly to use with the factory air bezel. His duct is designed to use the two top ac ports on the Vintage Air unit.
It's a pretty slick solution for your application.
spudder is offline   Reply With Quote
