Old 11-29-2019, 09:13 AM   #1
doo142
doo142's Avatar
56 horn button parts
Would someone please post pics of 56 steering wheel Horn contact parts? I have a stock wheel and horn button but nothing else , it would be greatly appreciated !! Thank you! (I would be willing to purchase these parts also)
72 Cheyenne k/20, Custom Camper
72 Cheyenne k/20
71 blazer K/5 2WD 454, 6 sp.
67 Chevy Napco c30 Dump
56 GMC Napco 4x4 short step
66 Chevy K10
68 Chevy C/30 4x4
doo142 is offline   Reply With Quote
Old 11-29-2019, 05:35 PM   #2
dsraven
Re: 56 horn button parts
post up some pics of what you have so we can see what's missing. include a pic of the steering column end under the wheel as well, if your wheel is off.
there should be an upper steering column bearing with a brass contact surface on it at the top of the column. it has a ground wire attached to it that goes down the column inside and comes out below the dash level. if that wire is touched to ground the horn should blow.
what style of signal switch do you have? under the steering wheel or attached to the side of the column?
Old 11-29-2019, 09:44 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Here you go, doo. This is from The Car and Truck Shop's website in Orange, CA. I picked their pictures just because they are who I use for parts, mostly. I'm sure all the aftermarket palaces have these parts. Also try LMC Truck. Best of luck!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 11-29-2019, 11:20 PM   #4
doo142
doo142's Avatar
Thanks to both of you , that is exactly what I needed. ✌️
72 Cheyenne k/20
66 Chevy K10
68 Chevy C/30 4x4
