Old 12-02-2019, 09:06 AM   #1
dennislbrooks
dennislbrooks's Avatar
Caliper bracket mount template for 55-59 w/12"rotors
Does any vender offer a template for the custom front caliper mount bracket for a 55-59?
I have seen the brackets with bolts only for conversion to small 5 but only complete kits for 6 lugs.
thanks
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 12-02-2019, 02:16 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Caliper bracket mount template for 55-59 w/12"rotors
You mean like these?: https://www.performanceonline.com/Di...uck-GMC-Truck/
Old 12-02-2019, 04:42 PM   #3
dennislbrooks
Yes, those brackets.
Old 12-02-2019, 04:46 PM   #4
The Rocknrod
Moderator
Have you called them to see if the bracket is different?
Old 12-02-2019, 06:22 PM   #5
dennislbrooks
I have not called Speedway but I do know the small 5 is 11 inch rotors instead of 12 inch for the 6 lug.
Old 12-19-2019, 03:50 PM   #6
dennislbrooks
I hailed the vendors and asked if anyone sold the mounting brackets only for a 6 lug 12" rotor disc brakes calipers for 55-59 chevy/gmc. I only found vendors who sold the 5 lug caliper mounting brackets only for 11" rotors.
So as some of you have done, I will create my own brackets for use with 78 K10 rotors and lug studs and 72 c10 calipers and hoses.
I will use either 5/16" or 3/8" --to be determined --- and I will trace my pattern for both sides
for future use.
These probably can be used with 15" wheels if you use a 1" spacer to clear the tie rod end which I doubt would hurt many of us. Dunno yet.
Again, input is appreciated. I wish a happy holiday to all.
Old 12-29-2019, 11:09 AM   #7
dennislbrooks
For those who like to fabricate. I used the universal bracket from Speedwaymotors - $10 each and 3/8" thick for the bolted bracket. The bracket tracings should be to scale on an 8 1/2 x 11 sheet of paper. Take the lines out on cutting. Many pics for reference. I used grade eight bolts for mounting and it rest against the spindle mount so it will not go anywhere. You save about half if you have the means to make them. You fit the 2 pieces with caliper on the bracket/rotor and clamp for proper placement on welding.
I can fax if necessary.
Old 12-29-2019, 11:11 AM   #8
dennislbrooks
more pics for setup.
