![]() ![]() Join Date: Feb 2009
Any last minute advice installing full moldings with all new holes?
I've sweated this one for years
![]() This truck had a paint separator only. We're adding full GM moldings on the sides and rear, tail bezels too. The bed came off another truck with full moldings, but the holes were welded up before I got it. This is a SWB fleetside Custom Deluxe, so it takes a lower molding as opposed a band on the tailgate. As side moldings go, only the upper fender moldings require a hole per clip (6 ea.). The kit (NOS) includes 3M tape clips for the rest, with a hole drilled for I think each end of the part. Yeah we could probably use 3M on all of it, but we’re drilling per the kit. Tried before for exact measurements, and still welcome any available. The assembly manual has them, but their initial reference points are meaningless. I do have a LWB with moldings I can reference for everything less the lower molding on the tailgate. LWB & SWB are basically the same. If I have to rip em off to see I will (ha!). Mostly kidding, but it’s just a beater. Any suggestions tips & appreciated.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-02-2019 at 10:55 PM. |
Re: Any last minute advice installing full moldings with all new holes?
I drilled holes where the stick on clips would have been, 11 on a bed side upper LWB...I think , and bought an extra pack of upper and lower clips, used no sticky clips. Bolts where you can reach, upper clips mostly push on. Layed down blue tape, strait edge across center of holes you have and equal space the rest....smaller drill 1st then correct size.
#3 | |
At the moment I'm looking for lower tailgate trim placement. So far I've come up empty. Here's an image from the assm. manual. The height is Greek to me:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-02-2019 at 10:13 PM. |
#4 | |
I've added trim where it had not been before but that was on my own trucks. I don't feel qualified to tell others how from afar. Haven't done it in a good while as well. Notsolo did a good job with what he offered. I wonder if this wouldn't be a good topic to take over to the paint and body forum.
![]() Join Date: Jan 2018
If you use aftermarket push in clips, layer 3M double sided tape behind them (especially the tailgate trim). On the tailgate, I used 4 layers and on the side trim I used 3. This allows the push ins to engage and not just "sink" back into the moulding. I also squared the holes I drilled a bit with a small file, if doing again I would drill the holes slightly small and then square them. NOS and OEM are great but the aftermarket clips work fine if you use the tape method. The aftermarket bolt style clips I personally like better than OEM as they are larger/stiffer. The top door trim front clip is a pain to put a nut on...I didn't use push ins on any of my "lead clips" as I had one pop off and away went the trim on the highway pre-paint and didn't want to risk it after paint. The adhesive clips suck, the trim stick way out from the body so it is tight, loose, tight and looks bad.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Looking at pictures, seems to make sense to install the taillight bezels before the upper and tailgate trim.
Preference on the slope of the upper bed trim, I like it factory, especially on a SWB. Here's a comparison.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-04-2019 at 05:32 PM. |
![]() Join Date: Jul 2015
Take lots of pictures please as I'm needing to do the same...
At the body shop.
I have a tailgate at home with all the holes for both pieces of trim and they're off.
I can lay a tape on any part you want a picture of to see tomorrow.
" That didnt make it any newer " " Dont antique the equipment " |
GM measurements could have been better. .66 up from the bottom of the tailgate to the center of the hole. (.625 is 5/8" ) .66 in a fraction is close to 21/32 right in between 5/8 and 11/16. Mine was a original CST gate with the lower holes, this is how they layed out.
SWB 4x4 Collector
![]() Join Date: Jun 2001
Main advice is on the upper trim, it doesn’t go in a straight line. There is a slight crown to it front to back. The bed tends to dive down front to back to go with the body line. Too many just run a straight line from front to back and the trim gets too high in the rear. I had factory upper holes still in tact in my bed here.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#12 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
I would suggest mounting the bed on the truck, with all body lines shimmed to your liking. Then lay out the trim. I've seen some trucks, where the trim was added to the bed while it was off the truck,... and looked terrible when installed. I know of a couple reputable truck builders that raise the rear of the upper trim to make it flow better "visually".
#13 | ||
If I feel right about it I plan to list everything with pics and measurements. Quote:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-03-2019 at 01:35 PM. |
I think what I would do is tape all the molding into place, making sure it is where you want it. Then with the molding taped, put tape on top and bottom of the body where the molding line is. then remove the molding. Now you have upper and lower tape to show where the molding would go. Then drill your holes in the center of the space. Should work.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
