Old 12-02-2019, 10:12 PM   #1
dz1087
Inner Cowl Blower Motor Mount Alignment
How does one get this part properly aligned? I had to remove it to weld up rust holes where it originally mounted. Now I’m worried I’ll get it put back on in the wrong place and then the fender will never line up properly.
Does anyone have dimensions on where the fender/cowl mounting holes should be located?
Related question: I need a new inner cowl due to rust. Do the new ones come with this piece?
dz1087 is offline   Reply With Quote
Old 12-05-2019, 10:59 AM   #2
dz1087
Re: Inner Cowl Blower Motor Mount Alignment
So, nobody ran in to this when re-attaching their inner cowl panel?
With shims, I'm assuming that left/right adjustments would be easy. It's the front/rear position I'm worried about getting right.
Old 12-05-2019, 12:43 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Inner Cowl Blower Motor Mount Alignment
I have my 68 torn a part if you want some measurements. It's factory you can tell by all the rust!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-07-2019, 07:22 PM   #4
dz1087
Thanks for the offer there.
I ordered a replacement so when it arrives I’ll look and see if it has the bracket included or not and then see how I need to attach it.
