12-08-2019, 01:16 PM | #1 |
Front inner wheel seal
I am in the process of converting my 68 to disc brake/drop spindles. I just want to clarify on the front inner wheel seal. I am seeing two different styles, one with a lip and one without a lip around the outer edge. I am 99% sure it’s the seal with the lip around the outer edge I need, like in the first picture. Also, I assume I need to put a bit of oil on the seal upon installing the rotor on the spindle. Below are the seals I’m seeing from rockauto. For the the ECE drop spindles I have I was told to use parts for a 71-72 c10, which are the seals listed below. Thanks.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 12-09-2019 at 12:09 AM. |
12-14-2019, 05:49 PM | #2 |
Re: Front inner wheel seal
I am going to assume everybody but me knew this one. But the correct seal is the one with the lip. National part # 8871 or SKF part # 19984.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
