Old 12-10-2019, 09:39 PM   #1
the ideaman
the ideaman's Avatar
480 horse Ls3 first start problems
Finally started my 480/376 LS3 and it will fire, but almost dies immediately. Twice it continued to run when we disconnected the maf sensor, but hunted. It continued to run when we connected the sensor. Using the gm computer and harness. No codes read. Help!
the ideaman is offline   Reply With Quote
Old 12-10-2019, 11:27 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: 480 horse Ls3 first start problems
Maybe sensor and tube diameter not the same as stock. Anything other than stock makes it run poorly without retune.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-10-2019, 11:55 PM   #3
the ideaman
Thank you, I'm using the GM tube designated for the LS3. Perhaps it's facing backwards. Will check this weekend.
Old 12-11-2019, 10:09 PM   #4
the ideaman
The MAF was facing backwards. Now it starts and runs well.
Old 12-30-2019, 03:02 PM   #5
the ideaman
Having put a couple miles on it I've got a few observations. First, it's really fast, like scare me fast. Anybody who tells you 480 plus horsepower is no big deal has bigger huevos than I do. Secondly, I need to move the throttle pedal up higher on the firewall and away from me. My leg is at a strange angle and it's very uncomfortable. We'll have to bleed the brakes again or get a vacuum reservoir for the power brakes. They are a little spongey and there is too much pedal before the brakes really grab. Finally, a hydraulic clutch is the way to go with a swap like this. No squeaks or groans. A nice linear engagement. Truck fires instantly and settles into a lopey idle almost immediately. It's a lot of fun to cruise around in.
Old 12-30-2019, 11:24 PM   #6
mongocanfly
mongocanfly's Avatar
Good deal....what do ya have it in?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-31-2019, 12:11 AM   #7
kipps
I second Mongo's question -- what's the ls3 mounted in?
Is it an engine from a donor car, or a GM performance crate engine?
Do you have a clutch pedal position sensor connected? What sensor? How's it mounted? Any pics?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 12-31-2019, 12:18 AM   #8
the ideaman
GMC crate engine with captainfab's hydraulic clutch setup. McLeod hydraulic throwout bearing on a tremec tko.
Old 12-31-2019, 12:20 AM   #9
the ideaman
Just after 1st fire.
Old 12-31-2019, 09:08 AM   #10
kipps
Looks like a nice truck. Too bad it's hanging from the roof...
Do you have a clutch pedal sensor wired into the engine computer? If so, do you have any pics of how you mounted that sensor to the pedal?
Old 01-02-2020, 10:21 AM   #11
the ideaman
No clutch pedal sensor. Why is one necessary? Engine is wired up using GMPP ecu.
