12-20-2019, 01:09 AM | #1 |
1966 c-10 v-8 mounts
Installing a 383 in my 66 Panel,been off the road since 1997, I threw away the engine mounts years ago. I had a 350 in it,was pulled out in 1997 so no mounts to match for new ones. so I figured I must have had 6 cylinder mounts on it as the mount pedestals have only 1 hole on the flat surface. The engine I now have is about 450 horse so I got the aftermarket pedestals for regular mounts with the long bolt sideways. they were a ***** to install had to actually drill new bolt holes in the frame. The engine now tilts upward looks like a altered, doesnt look right. I am concerned and have not driven it yet.Has anyone had a similar issue? Thanks for any comments,Paul
12-20-2019, 01:45 AM | #2 |
Re: 1966 c-10 v-8 mounts
If you use late model engine mounts and perches, you have to trim the upper frame.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
12-20-2019, 07:45 AM | #3 |
Post some pictures. That will help. All you needed to do was get a new set of mounts for the side of the engine and bolt the engine into the truck with the perches that were in it. The inline 6 and the V8 used the same perches. Note that the 292 has a different mount on one side. If it were mine I would put the stock perches back in and put the correct mounts on the engine and be done.
Jimmy Here is a link to show the mounts that go on the engine for the stock perches. https://www.summitracing.com/parts/p...del/c10-pickup
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-20-2019, 06:21 PM | #4 |
These were advertised for a 66, when I mocked them up they lined up with the factory bolt holes in the frame,once the engine was bolted up to the mounts
they were off, so I drilled new holes. They are the short urethane mounts, I rather not use rubber mounts , It would be a lot of work as I have the brake lines going thru on one side and the engine is ready to fire, guess I am in denial and should go back to stock,I would have to lift the engine up quite a bit,Thanks guysl |
12-20-2019, 09:37 PM | #5 |
Im going through this now with my 66, I cut my drivers side engine stand a few years back to clear a header tube. What I learned while looking for the drivers side stand was, I had 6 cyl stands. These 6 cyl stand will be in the back hole under the oil pan. The v8 stands I picked up Saturday mount in the front hole under the oil pan ,This hole is closer to the frame rail.
12-21-2019, 12:08 AM | #6 | |
60-66 Nut
What you are talking about is true for the '67-'72 trucks but NOT the '63-'66 trucks. The 230/250 I6 and the small blocks use the exact same engine mounts the exact same engine mount brackets and in the exact same rear location.
12-21-2019, 08:13 AM | #7 |
Let's say that's true, and it may be. Then why would chevy
Have two locations drilled in the chassis that matches Two different stands in a 66. |
12-22-2019, 01:03 AM | #8 |
I just went through this in my 66
a big block came out and i installed a Late model 350 V8 I had to make accommodations . It was hitting the manifolds and wrong angle on the pad Had to add !" on top and 3 " on bottom to use both Top two Bolt holes and The lower sloted Bolt hole... I don't know if this is my final Mount's..... But it does the job . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
12-23-2019, 11:05 AM | #9 |
Soft patch I would just get a set of stock stands and put in the truck. They are not that hard to find and your engine will be where it should be.
Jimmy
